How to connect to PS3 network thru PC
Old 22-09-2009, 4:48 PM   #1
Zon_Uzi's Avatar
1,232, Level: 7
Points: 1,232, Level: 7 Points: 1,232, Level: 7 Points: 1,232, Level: 7
Activity: 0.5%
Activity: 0.5% Activity: 0.5% Activity: 0.5%
Thanks: Gave 1, Got 0
well my router has packed it in as well and I was wondering if i can connect thru my PC? i tried last night but the ps3 could not pick up ip address or connect. when i connected my cat 5, on the network menu a pop up came up to say that the connection is limited or not connected. please let me know what to do ....
i use to connect thru wired router
thanks
Old 22-09-2009, 7:32 PM   #2
Zon_Uzi's Avatar
1,232, Level: 7
Activity: 0.5%
Re: How to connect to PS3 network thru PC
any one ? ? ?
Old 23-09-2009, 11:24 AM   #3
33,239, Level: 44
Points: 33,239, Level: 44 Points: 33,239, Level: 44 Points: 33,239, Level: 44
Activity: 20.6%
Activity: 20.6% Activity: 20.6% Activity: 20.6%
Thanks: Gave 527, Got 1,810
This thread may help
PS3 to PC DIRECT with either crossover or normal?
you will need a crossover cable if your PC doesn't have a Gigabit ethernet port. If it has then a standard Cat5e/6 cable will be fine.
Old 23-09-2009, 4:47 PM   #4
Zon_Uzi's Avatar
1,232, Level: 7
Activity: 0.5%
whats a Gigabit ethernet port ? is it just a standard ethernet point?
when i connect he cat5 i get a limited or no connectivity pop up !
Old 23-09-2009, 10:25 PM   #5
33,239, Level: 44
Activity: 20.6%
gigabit port is a 1000mb ethernet port. PS3 has one, some PC's do some don't. you need to check the spec of your PC's port. if it's normal 10/100mb then you will need a crossover Cat5 cable between the PS3 and PC. If your PC has a Gigabit port then a standard Cat5 between them will work.
Then just make sure both the PS3 and PC have network settings configured as per the thread i linked to above.
