Help please
Old 21-09-2009, 12:01 PM   #1
908, Level: 6
Points: 908, Level: 6 Points: 908, Level: 6 Points: 908, Level: 6
Activity: 0.9%
Activity: 0.9% Activity: 0.9% Activity: 0.9%
Thanks: Gave 1, Got 0
Help please
Any idea how you get rid of the annoying 3" black lines on the top and bottom of my screen whilst watching a blu-ray movie on the ps3?
Any way of zooming in the picture?
I have a 42" toshiba, but i am losing 6" off the screen size with the black lines.
Thanks in advance.
Old 21-09-2009, 12:17 PM   #2
5,112, Level: 16
Points: 5,112, Level: 16 Points: 5,112, Level: 16 Points: 5,112, Level: 16
Thanks: Gave 89, Got 52
Re: Help please
zoom key on your tv remote?
Unless it's a config error i would guess the bluray is in a > 16:9 ratio which means it'll have black bars, zooming will either stretch the picture or chop the sides off. I wouldn't recommend it as quality suffers and it's not how it was intended but it's your tv/ps3.
johnnyonone (21-09-2009)
Old 21-09-2009, 3:04 PM   #3
908, Level: 6
Activity: 0.9%
Re: Help please
No zoom on tv remote and cannot find on ps3.
zoom button on my home cinema, but not playing back the disk via the home cinema- just the optical sound.
I watched angels and demons and sure the aspect ratio of the blu-ray was 2:40 0r 2:45 if that is any help.
Old 22-09-2009, 12:00 PM   #4
5,112, Level: 16
Re: Help please
yep 2:35 - 2:45 would indeed give you bars at the top and bottom, just as a 4:3 would give you bars on the sides. In a cinema they'd just open/close the curtains to the approriate size but a screen is a fixed size.
i don't know if it'll work on bluray but the dvd setting to fix this are shown here, unfortunately i'm not able to check at the moment.
Old 22-09-2009, 3:09 PM   #5
908, Level: 6
Activity: 0.9%
Re: Help please
Still having no luck!!!
set my tv to auto format and tried changing the settings on the ps3, but still got the black blocks when playing back a dvd/bluray which as an aspect ratio of 2.40:1, but when i put in rise of the foot soldier dvd with an aspect ratio of 1.85:1 i get a full screen!!!
Is it just the way the film as been recorded?? Anomorphic widesceen???
Thanks for your time.
Old 22-09-2009, 4:12 PM   #6
5,112, Level: 16
Re: Help please
yep 1:78 & 1:85 will be exactly (or very ish) using your entire screen. have a look here as i think it explains better than i am able to. as an aside what make & model of tv do you have?
Old 23-09-2009, 12:51 PM   #7
908, Level: 6
Activity: 0.9%
Re: Help please
Hi Matt, my tv is the toshiba 42xv553db.
Thanks for the link. i guess i prefer to watch a film in full screen rather with the black lines present, but i didn't realize how much of the picture you lose with full screen.
Do you get the black lines whilst watching a film with an aspect ratio of 2.40:1 or similar???
Thanks again for your time.
Old 25-09-2009, 9:11 AM   #8
5,112, Level: 16
Re: Help please
Hiya, sorry for the delay in reply, didn't notice you had wrote back. In answer to your question :
2:35 & 2:40 will leave bars at the top and bottom of the screen.
16:9, 1:78, 1:85 will either exactly of very nearly (i say nearly as i think 1:85 with overscan will not show but i didn't want to go into explaining overscan) fit the screen.
And 4:3 & 1:33 will leave bars (big ones) on the left and right sides.
This is how it is with every widescreen screen (both mine included) that i know of that is set to widescreen or dot-by-dot mode. Your zoom/aspect/screen size button on your tv remote will toggle through all the available modes (on mine i can get ride of the top/bottom bars in zoom mode but the picture is stretched).
Sorry i can't be of anymore help but it's a nice tv and if i was you i'd not think of it as lossing height because of bars but gaining all the extra bits on the sides you never knew were there.
Old 26-09-2009, 2:21 PM   #9
3,097, Level: 13
Points: 3,097, Level: 13 Points: 3,097, Level: 13 Points: 3,097, Level: 13
Thanks: Gave 6, Got 34
Re: Help please
God, it's how it's supposed to look you twit! If your going to zoom, then your going to lose parts of the film!
Old 27-09-2009, 1:17 PM   #10
908, Level: 6
Activity: 0.9%
Re: Help please
Thanks for your help matt, i have sorted it, when you mentioned buttons on your tv remote i tried them all and one flashed up a menu with wide,superlive 2, cinema 2, 4:3, superlive 1, cinema 1 and 14:9. I purchased my tv from work for £400(ex-display) and could not find the manual for it, thats why i refered to this forum for help. Thanks again for your help.
