ps3 controllers
Old 18-09-2009, 10:11 PM   #1
2,967, Level: 12
Points: 2,967, Level: 12 Points: 2,967, Level: 12 Points: 2,967, Level: 12
Thanks: Gave 81, Got 5
ps3 controllers
my ps3 60gb has died and im gonna go for one of the argos bundles that includes an extra controller,should i bother as i have 2 with my old console,the ones i have are the with 4 lights are they all compatible and are the new ones any better.
thanks gaz..........
Old 18-09-2009, 11:02 PM   #2
1,378, Level: 8
Points: 1,378, Level: 8 Points: 1,378, Level: 8 Points: 1,378, Level: 8
Thanks: Gave 47, Got 88
Re: ps3 controllers
They're all compatable.
Does your vibrate ? If not, its a sixaxis - if it does then its a dualshock 3.
Dualshock 3 are the better newer ones.
Old 18-09-2009, 11:21 PM   #3
2,967, Level: 12
Re: ps3 controllers
thanks deejay.
mine dont vibrate,but there fine for cod.
mine have 4 lights so id thought maybe they were only compatible with the 60gb as it has 4 usb ports.
thanks for clearing this up.
gaz...........
Old 19-09-2009, 9:03 AM   #4
33,227, Level: 44
Points: 33,227, Level: 44 Points: 33,227, Level: 44 Points: 33,227, Level: 44
Activity: 23.5%
Activity: 23.5% Activity: 23.5% Activity: 23.5%
Thanks: Gave 527, Got 1,810
Re: ps3 controllers
Also the ones argos bundle in are usually nasty IR controllers.
Old 19-09-2009, 9:35 AM   #5
2,967, Level: 12
Re: ps3 controllers
thanks for that uridium,i noticed that late last night when the difference was explained by deejay,so i will probably go for prince of persia and far cry option.
i will get a 10% discount as the daughter in law works at argos plus there giving a tenner voucher for anything over £100,thi will knock the price down to £215.
do you guys know any better offers.
Old 19-09-2009, 10:21 PM   #6
Future Bhoy's Avatar
1,902, Level: 10
Points: 1,902, Level: 10 Points: 1,902, Level: 10 Points: 1,902, Level: 10
Thanks: Gave 10, Got 0
Re: ps3 controllers
This'll save me makin a new thread, If you use your Dualshock 3 wired do you get a slightly faster response time than having it wireless ? in games like FIFA can it make a difference..
Old 20-09-2009, 12:35 AM   #7
33,227, Level: 44
Activity: 23.5%
Re: ps3 controllers
Only if your name is Clark Kent
