New ps3, network login problem
Old 15-09-2009, 3:33 PM   #1
1,461, Level: 8
Points: 1,461, Level: 8 Points: 1,461, Level: 8 Points: 1,461, Level: 8
I've recently purchased the new slim ps3, to replace my old (blu-ray burnt out ) ps3. i've set up my internet connection, but everytime i try to login on my old psn sign-in and password i gt told the combination is wrong, i've checked on my old ps3 and can still login fine on there.
Old 15-09-2009, 4:06 PM   #2
7,534, Level: 20
Points: 7,534, Level: 20 Points: 7,534, Level: 20 Points: 7,534, Level: 20
Thanks: Gave 278, Got 201
Re: New ps3, network login problem
if your 100% your e-mails right you can get it reset to there or answer a security question iirc also probably easier to do it on your p.c then once you know the right info put it through your ps3.
Official PlayStation website: PlayStation Network, PSN
