Call of duty World at war invite errors,help!!!!
Old 04-08-2009, 9:12 AM   #1
1,782, Level: 9
Points: 1,782, Level: 9 Points: 1,782, Level: 9 Points: 1,782, Level: 9
Thanks: Gave 1, Got 0
Hi guys, im having errors when i invite friends or i get invited to their game.
I get
"game is no longer availiable" or" game is already active"
when i go to their game and vice versa. I can see the game struggling to join but it nearly gets there.
I understand this is a router problem, im not the best with computers of i someone could help me id be very grateful
I know how to get to my router config page.
Old 04-08-2009, 9:20 AM   #2
2,116, Level: 10
Points: 2,116, Level: 10 Points: 2,116, Level: 10 Points: 2,116, Level: 10
Thanks: Gave 6, Got 6
Re: Call of duty World at war invite errors,help!!!!
(Its coz ur not using an xbox, lol)
First get your PS3 IP address, example 192.168.0.123
Go to your router config -> port forwarding
Then forward the following ports, replace 192.168.0.123 with your PS3 IP address.
If you dont have an option for TCP or UDP, or it says 'Both', dont worry / select 'Both'
80 - 192.168.0.123 - TCP
443 - 192.168.0.123 - TCP
5223 - 192.168.0.123 - TCP
3478 - 192.168.0.123 - UDP
3479 - 192.168.0.123 - UDP
3658 - 192.168.0.123 - UDP
The last one 3658 is for voicechat.
That should be your PS3 ports setup on router side.
[Edit] If you need to find your PS3 IP, i think it will be in your PS3 network settings [/Edit]
cameroon95 (11-08-2009)
Old 08-08-2009, 7:59 PM   #3
2,514, Level: 11
Points: 2,514, Level: 11 Points: 2,514, Level: 11 Points: 2,514, Level: 11
Unhappy Re: Call of duty World at war invite errors,help!!!!
i have the same problem.
i opened all the suggested ports but i still have a nat type 3
any help
Old 12-08-2009, 5:09 PM   #4
2,300, Level: 11
Points: 2,300, Level: 11 Points: 2,300, Level: 11 Points: 2,300, Level: 11
Thanks: Gave 21, Got 12
does your ps3 have a static ip.. right? Also see on your router page whether u have something called uPnP, if u do enable it. If your ps3 can connect to your router with uPnP available then u shud (touch wood) get nat2
