ps3 and wireless router
Old 27-05-2009, 7:11 PM   #1
2,458, Level: 11
Points: 2,458, Level: 11 Points: 2,458, Level: 11 Points: 2,458, Level: 11
does a wireless router have to be set up through a pc first before you can set up a ps3 with it? my brother in law has ps3 and internet access but no pc or laptop,how does he go about setting up a new router for the ps3 or will he need to borrow a laptop to set it up first?
hope that all made sense
thanks
carlchelski
Old 27-05-2009, 7:24 PM   #2
2,712, Level: 12
Points: 2,712, Level: 12 Points: 2,712, Level: 12 Points: 2,712, Level: 12
Thanks: Gave 63, Got 44
Re: ps3 and wireless router
Possibly yes, However if the router has been probably pre-configured and has DHCP enabled then I think you can connect the PS3 to the router using an ethernet cable and configure the router from the PS3's internet browser.
