Need to confirm PS3\Router Settings
Old 10-05-2009, 6:34 PM   #1
4,771, Level: 16
Points: 4,771, Level: 16 Points: 4,771, Level: 16 Points: 4,771, Level: 16
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 47, Got 22
Please could someone confirm these settings for me.
I'm trying to connect to my mate,so we can play various coop games together.
So i am try to get both the PS3 and routers set up.....
Is there anything else that i need to do ?.........Thanks !
PS3
Static ip : 10.0.0.4
Subnet Mask : 255.255.255.0
Router ip : 10.0.0.2
Primary DNS : 10.0.0.2
Secondary DNS : 10.0.0.2
MTU : Automatic
Proxy Server : Do Not Use
UPnP : Enabled
Internet Connection : Enabled
PC
UPnP : Enabled
DMZ \ Port fowarding :
PS3 ip Address Protocol Start \ End Port
1.0.0.4 TCP 80 80
1.0.0.4 TCP 443 443
1.0.0.4 TCP 5223 5223
1.0.0.4 UDP 3478 3478
1.0.0.4 UDP 3479 3479
1.0.0.4 UDP 3658 3658
1.0.0.4 UDP 4658 4658
Old 10-05-2009, 7:46 PM   #2
33,239, Level: 44
Points: 33,239, Level: 44 Points: 33,239, Level: 44 Points: 33,239, Level: 44
Activity: 20.6%
Activity: 20.6% Activity: 20.6% Activity: 20.6%
Thanks: Gave 527, Got 1,810
Re: Need to confirm PS3\Router Settings
Are you trying to play with 2x PS3's on the same LAN?
Old 11-05-2009, 6:48 PM   #3
4,771, Level: 16
Activity: 0.8%
No.........Just trying to connect to my mate through the interent.
I think its working now as we have just connected up for the first time on hawx !
