Can You Port Forward For PS3
Old 22-11-2009, 5:55 PM   #1
3,561, Level: 14
Points: 3,561, Level: 14 Points: 3,561, Level: 14 Points: 3,561, Level: 14
Thanks: Gave 19, Got 4
well my MW2 is somtimes very laggy and i was wondering if there was anyway to increase the connection stregth and stability.
Is there any port forwarding settings (E.G specific ports) that will make my connection better?
cheers
Old 01-12-2009, 4:20 PM   #2
8,379, Level: 21
Points: 8,379, Level: 21 Points: 8,379, Level: 21 Points: 8,379, Level: 21
Activity: 5.1%
Activity: 5.1% Activity: 5.1% Activity: 5.1%
Thanks: Gave 413, Got 375
cheers
Have a look at this site mate, if you scroll down the list of ports you will see some specifically for some PS3 games and also the PS3 network etc...
PortForward.com - ReplaceTitle
It may also be a good idea to put your PS3 into DMZ mode this may help aswell..
GUIDE: PUT YOUR PS3 IN A DMZ
Also using wired connections instead of wireless connections if applicable also helps things.
Hope the above helps...
TonkaToys (17-12-2009)
Old 17-12-2009, 12:14 PM   #3
1,058, Level: 7
Points: 1,058, Level: 7 Points: 1,058, Level: 7 Points: 1,058, Level: 7
Activity: 1.2%
Activity: 1.2% Activity: 1.2% Activity: 1.2%
Thanks: Gave 28, Got 11
Out of interest, does portforwarding make a significant difference?
I too am playing (badly) MW2 and any advantages are welcomed .
