PS3 Belkin connection problems
Old 13-08-2009, 8:01 PM   #1
1,371, Level: 8
Points: 1,371, Level: 8 Points: 1,371, Level: 8 Points: 1,371, Level: 8
Wondering if anyone can help me, I just bought a Belkin N+ Router which connects to my desktop and laptop no problem. When I try and connect to my ps3 its another story altogether, no matter what I ve tried it doesnt seem to work. When I follow the network connect instructions on the ps3, easy, scan etc it always comes back with either cant find access point or an error code 8013013D. The ps3 finds the router and shows the connection as 60% strength but always fails when finding the IP address.
My ISP is tiscali.
Please help as I cant even download the latest updates for ps3.
Mike
Old 23-08-2009, 11:28 AM   #2
1,812, Level: 9
Points: 1,812, Level: 9 Points: 1,812, Level: 9 Points: 1,812, Level: 9
Re: PS3 Belkin connection problems
Have you managed to solve this problem? I've got exactly the same thing!
Old 25-08-2009, 1:54 PM   #3
4,002, Level: 14
Points: 4,002, Level: 14 Points: 4,002, Level: 14 Points: 4,002, Level: 14
Same problem here. After searching many posts and general google searching I'm very very close to taking it back and switching to a different make.
Old 25-08-2009, 4:37 PM   #4
Thanks: Gave 428, Got 365
You need to put the PS3 into DMZ, On your router setup page.....usually 192.168.2.1
Old 28-08-2009, 12:57 PM   #5
3,291, Level: 13
Points: 3,291, Level: 13 Points: 3,291, Level: 13 Points: 3,291, Level: 13
Thanks: Gave 38, Got 63
edit wrong thread
