belkin router problems
Old 30-07-2009, 12:43 AM   #1
1,918, Level: 10
Points: 1,918, Level: 10 Points: 1,918, Level: 10 Points: 1,918, Level: 10
since switching from a wired connection on my ps3 to a wireless one i keep getting signed out during games or while im browsing. Its really annoying as i havent been able to do any online gaming in a while, the router is a belkin wireless G router.
thanx for any help EDD
Old 30-07-2009, 5:23 PM   #2
1,918, Level: 10
Re: belkin router problems
the error code i keep getting is 8oo2ad23, anybody got any ideas???
Old 10-08-2009, 11:02 PM   #3
3,968, Level: 14
Points: 3,968, Level: 14 Points: 3,968, Level: 14 Points: 3,968, Level: 14
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 69, Got 72
Simply a bad wireless connection. Only things I can think of are ~
Change the channel
Reboot the router back to default
or physically move the router to a better place
You might also consider switching off the hardware firewall when using it with the PS3
Old 11-08-2009, 12:29 AM   #4
5,858, Level: 18
Points: 5,858, Level: 18 Points: 5,858, Level: 18 Points: 5,858, Level: 18
Activity: 11.1%
Activity: 11.1% Activity: 11.1% Activity: 11.1%
Thanks: Gave 576, Got 149
I think the error code you've copied down is wrong, it's zeros (0) rather than o's. If you Google 8002ad23 instead, you'll find a lot of similar reports with Belkin routers, hopefully maybe even a solution
Old 28-08-2009, 12:52 PM   #5
3,291, Level: 13
Points: 3,291, Level: 13 Points: 3,291, Level: 13 Points: 3,291, Level: 13
Thanks: Gave 38, Got 63
Lo there,
I had a similar problem with a Belkin and a PS3. It turns out it was something to do with the Belkin router automatically updating it's time. there's a command you can type in somewhere on the router which fixed it. the only problem was that it was not a permanent thing so you had to redo the command if you rebooted the router.
I'll see if I can find it when I get home and post.
Rob
Old 28-08-2009, 12:59 PM   #6
3,291, Level: 13
A quick search found what I was looking for. this applies to the N1 but should apply to yours to.
http://www.avforums.com/forums/netwo...n1-vision.html
and
[Split] Belkin N1 Vision: disconnects on a 2-hour intereval - dslreports.com
