HLP PLS - PS3 to Projector via HDMI to DVI - No Sound? Does PS3 have Jack Output?
Old 15-07-2009, 2:09 PM   #1
3,362, Level: 13
Points: 3,362, Level: 13 Points: 3,362, Level: 13 Points: 3,362, Level: 13
Thanks: Gave 5, Got 0
Hi All a per the title - trying to connect my PS3 to Projector ( no HDMi input on projector) so having read up on it I understand I need Hdmi lead from PS3 to Projector (DVI) to improve the picture quality (does anyone know if i will get 1080 via this lead or just a simple improvement over SD?)
So the HDMI to DVI should sort the picture but with no sound. So i read this suggestion for sound '2x RCA Phono Female to 1x 3.5mm Male Jack Audio Cable for Sound'. However looking at my PS3 I can't see any inputs for the Jack cable - am I going blind? if so where is it please!!
Finally does anyone know of a decent but cheap projection screen?
many thanks for any help
fraz
Old 17-07-2009, 12:01 PM   #2
3,644, Level: 14
Points: 3,644, Level: 14 Points: 3,644, Level: 14 Points: 3,644, Level: 14
Thanks: Gave 75, Got 69
Re: HLP PLS - PS3 to Projector via HDMI to DVI - No Sound? Does PS3 have Jack Output?
Just use the AV connector that came with the PS3, then go to audio settings and just put AV connector as audio selection
Old 17-07-2009, 12:08 PM   #3
3,362, Level: 13
OK thanks for your help mate I will give that a go.
