Last week I posted this:
Anyone had problems getting onto the PSN this weeikend?
But its gone on a long way from that post and I figured that a new post might be the way to get help...
Lets forget the history and tell you where I am now.
I have a DG834G V3 and assuming that I have just rebooted it, EVERYTHING works..
However, if I leave it for a period of time (less then 24 hours), when I first connect to PSN, it times out. I can reproduce this over and over by either 'turning off' the PS3 and then switching it back on (in software, not by the plug) or by simply alternating between my US and UK accounts... Every time I connect for the first time, I get a 'Timeout'.. However if I keep retrying (perhaps 2-5 times) I eventually get in. However when I start a game, it doesn't connect.. For example COD sticks at the "Downloading Game Settings" screen.. Warkhawk stops at the "Initializing Connection"...
Before I continue I should point out that I am currently Wired.. I have also tried Wirless and its the same.. But I wanted to say this, as I know there are security incompatibilities with the PS3 and DG834G and want to distance myself from that!
When its in this state, EVERYTHING else works.. For example I can:
1. Surf the net from the PS3
2. Use ALL aspects of the internet from a Wired PC (Surfing, Downloading, Streaming, Torrentz)
3. Use ALL aspects of the internet from a Wireless PC
4. Use the Internet using an iPod Touch
5. Connect to my Wired PC using FTP (port 21) from an external source
6. Connect to my 'Slingbox' using Port 5001 from an external source
But connecting to the PSN and/or trying to play games is impossible... HOWEVER, if I reboot the router, the problem is fixed.. I can connect to the PSN immediatly and games play fine.. But it only stays this way for less than a day.
I am starting to think that its the way I am quiting COD or 'turning off' my PS3 which is causing this. I wonder if a port is hanging or locking up?? What I need to do is a test where I reboot the router, leave it for a few days (doing nothing with the PS3) and then see what happens. But to be honest, when I first installed the Netgear I didn't use the PS3 for a few days and the first time I came to try, I had this problem (hence my inital post).
Now its not like I am an idiot? Believe it or not, I DO know what I am doing (some might disagree with that statment). I work in Technical Support for a large Telecoms manufacturer, based in in their 'IP' division supporting "core" routers, so I am not new to this and have worked with IP for the past 20 years!
But I am stumped.. Other than a fault, or a bug I can't work out whats wrong.. To rule out he bug, I am trying ALL of the firmwares available.. However, I have been able to reproduce this in 4.01.06, 4.01.30, 4.01.37 and 4.01.40, so its not looking good.
So that leaves a fault.. Luckly, my router is provided as a 'work tool' so I simply got a replacement from my IT dept.. This time it was a V4.. I installed it.. And immediatly got logged in.. Then I played COD and got past the 'Downloading Game Settings'.. Then I got to 'Setting Up Game' and it didn't continue.. I could hear voice people playing the game through their headsets, but my game never started... I tried over and over and over and it would also sit at this point.. So finally I left it and found that after a number of minutes, it WOULD connect.. But when it did, I have never see 'lag' like it.. Everyone was just jumping all over the place and it was impossible to play.. So I have found the V4 even worse (Different but worse) than the V3.
So my knee jerk reaction is to blame the router as "not fit for purpose".. But when you think that there are more than 20 million PS3s, many (most) of which are on-line, there must be MILLIONS of people using Netgears.. Even if you consider there are 5 versions of the DG834G and then consider that some people switch theirs off every day so might not see this you are still left with Millions of people who potentially use the DG834G V3 and I have not found ANY posts on ANY forums from people who have similar problems.
Believe me I have tried everything.. Static, Dynamic IP addresses.. Internal/External DNS... Wireless/Wired.. Manual Ports.. uPnP.. DMZ... But at the end of the day, its not exactly rocket science and there isn't really much to configure.. I am now out of ideas and other than trying the last few Firmwares available, I don't know what to do next.
It seems my only option is to go back to my Thompson which has given me years of faultless service (but is hopelessly out-dated in terms of features), or to buy another router..
The purpose of this post is simply to hear from other DG834G users to find out whether you have problems... As long as I know that there are others out there, I alteast have hope!!.. But for now, I havn't seen a single indication that ANYONE is using the DG834G V3 so feel that I am alone!
My fingers are crossed that someone can help and I look forwards to hearing from you.
Sorry for the long post, but I had to get all my thoughts down!!
All the best
Jon
