Re: Satellite >> Dish >> Modem >> HomePlugs >> BT Wireless Router >> PS3
The current setup that i am trying at the moment is the original attempted (NAT 1) connection, with this i am able to type what you see before you now (fixed IP address). However the console still suggests that it is in fact NAT 3. I tried CoD again prior to updating this thread, still no luck in getting online... The game goes through ots normal checks, eg "Downloading game data" - this one doesn't last long, Afterwards my username shows up in the top right, then "reading HDD" appears, no problem here. Then comes the horrendously long "Downloading game data" which goes on for ages... and on occasions a sporadic burst of machine-gun-like sound erupts from the TV's speakers. (God knows what that is all about...). In the menu it also shows that apparently "0 players are online".
I tried to install the router again tonight, however i discovered that it was infact a so called "ADSL" wireless router. I tried it anyway, downloading its driver and installed it on my ancient laptop. I connected up the USB cable to the laptop and both the ethernet input and the other end of the USB into the back of the router, turned it on and lo and behold it worked (the laptop had previiously been able to work with the ethernet cable directly connected to the back of it, again with a fixed IP address). The wireless functionality however did not (for an unknown reason).
I am unsure if when i change the filtering of the internet (found in an obscure tab in connection settings) off on the laptop does it turn it off on the actual modem and/or router, or is it just the laptop settings themselves?
I also cannot manage to access the BT Port Forwarding page in IE (192.168.1.1) as it goes staight to the Avanti Satellite connection page (which does not appear to show any information on Forwarding) even when the BT router is between it and the laptop itself. Any way around this?
I have been advised by the person that installed the Satlink modem that i should connect a "4-way Network Hub" would this solve the problem? If so can you suggest any that would be suitable for the PlayStation?
I am begginning to wonder that it is the actual connection speed and/or the latency associated with the satellite broadband. I did a speed test and discovered that it was only an 8th of a meg approximately, and the ping being very large at approx 1700ms. Both of these values are expected though because at the moment i am using it "un-officially" i.e. it is not to be at full speed (1/2Mbs-1) until the first week of June, i believe that they have forgotten to turn it off after installation. Still, free's free right. ;-)
I am open to any ideas / suggestions, any help would be greatly appreciated...
