What would be better the built it wireless or Home plug?
Old 17-05-2009, 6:55 PM   #1
jedifozzie's Avatar
3,531, Level: 13
Points: 3,531, Level: 13 Points: 3,531, Level: 13 Points: 3,531, Level: 13
Thanks: Gave 114, Got 62
On a ps3 what would be better and are the home plugs any good?
Old 18-05-2009, 12:19 PM   #2
1,733, Level: 9
Points: 1,733, Level: 9 Points: 1,733, Level: 9 Points: 1,733, Level: 9
Thanks: Gave 2, Got 1
Re: What would be better the built it wireless or Home plug?
I have an internet connection set up that involves Homeplugs, (be it rather tempremental due to other problems, such as port forwarding etc.) and i recommend using them rather than a wireless setup. Although if you combined them (like i have), so that the homeplugs were distributing a signal to a wireless router elsewhere in your home (closer to where you want to connect) then you can have the best of both worlds, a strong signal and wireless options (psp, laptop etc.)
jedifozzie (18-05-2009)
