PS2 Singstar Disks on PS3 problem
Old 24-03-2009, 6:54 PM   #1
6,477, Level: 19
Points: 6,477, Level: 19 Points: 6,477, Level: 19 Points: 6,477, Level: 19
Thanks: Gave 179, Got 188
Hi Guys, we have some PS2 singstar discs. They play fine, until we try to do medleys. This results in a freeze, and having to reset the PS3. Is this a problem for anyone else?
Old 25-03-2009, 10:30 AM   #2
2,750, Level: 12
Points: 2,750, Level: 12 Points: 2,750, Level: 12 Points: 2,750, Level: 12
Thanks: Gave 35, Got 6
Re: PS2 Singstar Disks on PS3 problem
Yes, we are getting this problem as well. At first I thought it was just sorting which songs to use but after about 5 minutes it was clearly not going to do anything
This happens when a PS2 disc is inserted by pressing select on a PS3 disc and swapping them over...I haven't tried it by starting the PS2 disc in the PS3 first though.
Sorry I can't help you with this...just letting you know you're not alone.
Paul.B2 (25-03-2009)
Old 25-03-2009, 2:43 PM   #3
6,477, Level: 19
Thats the only way to play the PS2 discs unless you have one of the older 60GB PS3s.
Glad its not just me with this problem though.
Old 26-03-2009, 7:56 AM   #4
2,750, Level: 12
Luckily, (or not!) I have a launch 60GB PS3 so it can run PS2 discs no problem.
I haven't had chance to check to see if it works ok when running the PS2 disc on it's own as I have been formatting a 500GB hard drive for my PS3 and it took 30 odd hours.
I will check to see if it still happens after loading the PS2 disc on it's own,
although I suspect this will work ok.
