Originally Posted by Uridium Not as well as a PCH though. with a PCH you will get full DVD menu's etc...just as if you had placed the DVD in the tray
with PS3MS on the PS3 you just get the movie files from within the ISO |
Just to add Uridum if you rip DVD ISO's using DVDFab (basic version is free) you can select to rip only the main movie. This makes it much easier to select and play ISO movies from the PS3 XMB using PS3MS.
I would agree with Axum that you should go with the PS3 and PS3 Media Server route. I think this is a more future proof solution and provides you with alot more options for streaming.
Sony will always continue to update XMB and launch complatible hardware with the PS3.
Currently I have a PSP that I use to connect to my PS3 via remote play. I use it mainly as a remote control for my music when walking about the house, but I can also stream movies to it.
I can't wait to get my hands on the new Sony mobile phones that are remote play compatible. That way I can have access to all of my music/photos and videos from anywhere. I am sure Sony also has plans on upgarding the Walkman MP3 to be remote play compatible.
These are all features that PCH can't do and while you might not use them now I am sure once you get bitten by the bug and have all your media in one place you will start thinking about all these additional cool features.
