Media streaming - HELP please!
Old 03-11-2009, 2:11 PM   #1
4,339, Level: 15
Points: 4,339, Level: 15 Points: 4,339, Level: 15 Points: 4,339, Level: 15
Thanks: Gave 3, Got 0
For quite some time now I have successfully streamed data from my PC to my PS3 via TVersity and MediaPlayer and more recently via the excellent PS3 Media Server with no real problems.
A friend of mine has recently acquired a PS3 and has been having problems and has asked me to help. The PS3 itself works fine and accesses the internet OK, plays games etc. And from MY laptop logged into HIS network (and his router of course) it happily streams data. But his own PC (laptop) will not stream data. PS3 Media Server on his PC sees the PS3 and, looking at the 'Traces', appears to do everything it should do in trying to connect to the PS3 - ('It's ready! You should see the server appears on XMB etc') but whatever I try the media server is not recognised by the PS3. I've disabled firewalls and checked that his router is not in some way blocking access but to no avail. UPnP is enabled - I've read the help link supplied in the PS3 FAQs - can't think what the problem could be.
But networking has always been a bit of a mystery to me so I'd very much appreciate any feedback from you guys out there!
Thanks very much. Bob J
Old 03-11-2009, 5:19 PM   #2
33,222, Level: 44
Points: 33,222, Level: 44 Points: 33,222, Level: 44 Points: 33,222, Level: 44
Activity: 24.6%
Activity: 24.6% Activity: 24.6% Activity: 24.6%
Thanks: Gave 527, Got 1,810
Re: Media streaming - HELP please!
First things to try
- Double check that ALL firewall/security software is disabled (just to test) inc. windows firewall
- Try changing the Port number of PS3MS from 5001 (try 5005) in general settings
-Try forcing the IP address of his PC in PS3MS general settings tab
- Browse to C:\Program files\ps3 media server and paste the content of the file named "debug.log" on here (open it in notepad) as this will give us some more to work on....
(if file is very large delete the content, save and restart Ps3MS to recapture any errors)
Old 03-11-2009, 7:20 PM   #3
4,339, Level: 15
Thanks for that.
I'll try the things you've suggested and will post the debug log if I get no joy.
One other thing I should have made clear and which may be helpful is that the Windows Media Player server is also not seen by the PS3. With MY laptop both the PS3MS and MediaPlayer media servers are recognised. Your fixes seem only to apply to sorting out the PS3MS - maybe I'm mistaken here? - and that the problem may not be PS3MS specific.
Thanks again for coming back so promptly.
Bob J
Old 03-11-2009, 7:25 PM   #4
33,222, Level: 44
Activity: 24.6%
Thanks for that.
Bob J
If it's not seeing any DLNA servers then that basically points to it being either a Network or firewall config issue.
Reason i say stick with PS3MS is at least it gives you some logging info and some network config options config so you can look at the trace log for some clues.
With WMP you get nothing.....
Old 03-11-2009, 7:32 PM   #5
4,339, Level: 15
I see what you mean.
Cheers, Bob
Old 03-11-2009, 9:18 PM   #6
4,339, Level: 15
No luck so far.
Here is the log file.
(Port changed to 5005)
Sorry if the file is unnecessarily long - this is as it was emailed to me.
Any help gratefully received!
[main] TRACE 19:45:42.765 Starting Java PS3 Media Server v1.10.51
[main] TRACE 19:45:42.765 by shagrath / 2008-2009
[main] TRACE 19:45:42.765 PS3 Media Server
[main] TRACE 19:45:42.765 ps3mediaserver - Project Hosting on Google Code
[main] TRACE 19:45:42.765 Java 1.6.0_16-Sun Microsystems Inc.
[main] TRACE 19:45:42.765 OS Windows XP x86 5.1
[main] TRACE 19:45:42.765 Encoding: Cp1252
[main] TRACE 19:45:42.781 Temp folder: C:\DOCUME~1\SARAJO~1\LOCALS~1\Temp\javaps3media
[main] TRACE 19:45:42.796 AVISynth not found! Transcoder profile AviSynth/FFmpeg will not be used!
[main] TRACE 19:45:42.796 Registering transcoding engine FFmpeg Audio
[main] TRACE 19:45:42.812 Registering transcoding engine MEncoder
[main] TRACE 19:45:42.812 AVISynth not found! Transcoder profile Avisynth/MEncoder will not be used!
[main] TRACE 19:45:42.812 Registering transcoding engine MPlayer Audio
[main] TRACE 19:45:42.812 Registering transcoding engine MEncoder Web
[main] TRACE 19:45:42.812 Registering transcoding engine MPlayer Video Dump
[main] TRACE 19:45:42.812 Registering transcoding engine MPlayer Web
[main] TRACE 19:45:42.828 Registering transcoding engine TsMuxer
[main] TRACE 19:45:42.828 Registering transcoding engine Audio High Fidelity
[main] TRACE 19:45:42.828 Executable of transcoder profile VideoLan Audio Streaming not found!
[main] TRACE 19:45:42.828 Executable of transcoder profile VideoLan Video Streaming not found!
[main] TRACE 19:45:42.828 Registering transcoding engine FFmpeg DVR-MS Remux
[main] TRACE 19:45:42.828 Registering transcoding engine Raws Thumbnailer
[main] TRACE 19:45:42.828 AviSynth in not installed ! You cannot use avsmencoder as transcoding engine !
[main] DEBUG 19:45:43.171 Search extension for C:\Sara - Home\photos [Gid - 091017]
[main] INFO 19:45:43.171 Adding photos [Gid - 091017] / class: net.pms.dlna.RealFile
[main] INFO 19:45:43.171 Adding Web / class: net.pms.dlna.virtual.VirtualFolder
[main] INFO 19:45:43.171 Adding Pictures / class: net.pms.dlna.virtual.VirtualFolder
[main] INFO 19:45:43.171 Adding 1257277543171 / class: net.pms.dlna.ImagesFeed
[main] INFO 19:45:43.171 Adding Albums / class: net.pms.dlna.virtual.VirtualFolder
[main] INFO 19:45:43.171 Adding Radios / class: net.pms.dlna.virtual.VirtualFolder
[main] DEBUG 19:45:43.171 Search extension for http://www.jetfm.asso.fr/site/stream...haut_debit.m3u
[main] DEBUG 19:45:43.171 Found 1! net.pms.formats.WEB
[main] INFO 19:45:43.171 Adding JET FM (French Radio) / class: net.pms.dlna.WebAudioStream
[main] INFO 19:45:43.187 Switching JET FM (French Radio) to player: MPlayer Web
[main] INFO 19:45:43.187 Adding Radios With VLC [vlcaudio] / class: net.pms.dlna.virtual.VirtualFolder
[main] DEBUG 19:45:43.187 Search extension for http://www.jetfm.asso.fr/site/stream...haut_debit.m3u
[main] DEBUG 19:45:43.187 Found 1! net.pms.formats.WEB
[main] INFO 19:45:43.187 Adding JET FM (French Radio) / class: net.pms.dlna.WebAudioStream
[main] DEBUG 19:45:43.187 Search extension for SHOUTcast Administrator
[main] INFO 19:45:43.187 Adding Smooth Jazz / class: net.pms.dlna.WebAudioStream
[main] INFO 19:45:43.187 Switching Smooth Jazz to player: MPlayer Web
[main] DEBUG 19:45:43.187 Search extension for http://www.abacast.com/media/pls/cla...ical899-96.pls
[main] INFO 19:45:43.187 Adding KBPS All-classical / class: net.pms.dlna.WebAudioStream
[main] INFO 19:45:43.187 Switching KBPS All-classical to player: MPlayer Web
[main] INFO 19:45:43.187 Adding TVs / class: net.pms.dlna.virtual.VirtualFolder
[main] DEBUG 19:45:43.187 Search extension for mms://stream1.france24.yacast.net/f24_liveen
[main] INFO 19:45:43.187 Adding France 24 / class: net.pms.dlna.WebVideoStream
[main] INFO 19:45:43.187 Switching France 24 to player: MEncoder Web
[main] INFO 19:45:43.187 Duplicate France 24 with player: MEncoder Web
[main] INFO 19:45:43.187 Adding France 24 / class: net.pms.dlna.FileTranscodeVirtualFolder
[main] DEBUG 19:45:43.187 Search extension for mms://vipmms9.yacast.net/bfm_bfmtv
[main] INFO 19:45:43.187 Adding BFM TV (French TV) / class: net.pms.dlna.WebVideoStream
[main] INFO 19:45:43.187 Switching BFM TV (French TV) to player: MEncoder Web
[main] INFO 19:45:43.187 Duplicate BFM TV (French TV) with player: MEncoder Web
[main] INFO 19:45:43.187 Adding BFM TV (French TV) / class: net.pms.dlna.FileTranscodeVirtualFolder
[main] INFO 19:45:43.187 Adding {Tests} FreeboxTV (French Set-top Box) [mplayervideodump] / class: net.pms.dlna.virtual.VirtualFolder
[main] DEBUG 19:45:43.187 Search extension for rtsp://mafreebox.freebox.fr/fbxtv_pub/stream?namespace=1&service=201&flavour=sd
[main] INFO 19:45:43.187 Adding France 2 / class: net.pms.dlna.WebVideoStream
[main] INFO 19:45:43.187 Switching France 2 to player: MPlayer Video Dump
[main] INFO 19:45:43.187 Duplicate France 2 with player: MPlayer Video Dump
[main] INFO 19:45:43.187 Adding France 2 / class: net.pms.dlna.FileTranscodeVirtualFolder
[main] DEBUG 19:45:43.187 Search extension for rtsp://mafreebox.freebox.fr/fbxtv_pub/stream?namespace=1&service=691
[main] INFO 19:45:43.187 Adding France 2 HD / class: net.pms.dlna.WebVideoStream
[main] INFO 19:45:43.187 Switching France 2 HD to player: MPlayer Video Dump
[main] INFO 19:45:43.187 Duplicate France 2 HD with player: MPlayer Video Dump
[main] INFO 19:45:43.187 Adding France 2 HD / class: net.pms.dlna.FileTranscodeVirtualFolder
[main] DEBUG 19:45:43.187 Search extension for rtsp://mafreebox.freebox.fr/fbxtv_pub/stream?namespace=1&service=658
[main] INFO 19:45:43.187 Adding Nolife / class: net.pms.dlna.WebVideoStream
[main] INFO 19:45:43.187 Switching Nolife to player: MPlayer Video Dump
[main] INFO 19:45:43.187 Duplicate Nolife with player: MPlayer Video Dump
[main] INFO 19:45:43.187 Adding Nolife / class: net.pms.dlna.FileTranscodeVirtualFolder
[main] INFO 19:45:43.187 Adding Youtube / class: net.pms.dlna.virtual.VirtualFolder
[main] INFO 19:45:43.187 Adding 1257277543187 / class: net.pms.dlna.VideosFeed
[main] INFO 19:45:43.187 Adding PS3 / class: net.pms.dlna.virtual.VirtualFolder
[main] INFO 19:45:43.187 Adding Playlist / class: net.pms.dlna.virtual.VirtualFolder
[main] INFO 19:45:43.187 Adding GameTrailers / class: net.pms.dlna.virtual.VirtualFolder
[main] INFO 19:45:43.187 Adding Podcasts / class: net.pms.dlna.virtual.VirtualFolder
[main] INFO 19:45:43.187 Adding 1257277543187 / class: net.pms.dlna.AudiosFeed
[main] INFO 19:45:43.203 Adding All Audio Tracks / class: net.pms.dlna.virtual.MediaLibraryFolder
[main] INFO 19:45:43.203 Adding All Audio Playlists / class: net.pms.dlna.virtual.MediaLibraryFolder
[main] INFO 19:45:43.203 Adding By Artist / class: net.pms.dlna.virtual.MediaLibraryFolder
[main] INFO 19:45:43.203 Adding By Album / class: net.pms.dlna.virtual.MediaLibraryFolder
[main] INFO 19:45:43.203 Adding By Genre / class: net.pms.dlna.virtual.MediaLibraryFolder
[main] INFO 19:45:43.203 Adding By Artist/Album / class: net.pms.dlna.virtual.MediaLibraryFolder
[main] INFO 19:45:43.203 Adding By Genre/Artist/Album / class: net.pms.dlna.virtual.MediaLibraryFolder
[main] INFO 19:45:43.203 Adding By Date / class: net.pms.dlna.virtual.MediaLibraryFolder
[main] INFO 19:45:43.203 Adding By Letter/Artist/Album / class: net.pms.dlna.virtual.MediaLibraryFolder
[main] INFO 19:45:43.203 Adding Audio / class: net.pms.dlna.virtual.VirtualFolder
[main] INFO 19:45:43.203 Adding All Photos / class: net.pms.dlna.virtual.MediaLibraryFolder
[main] INFO 19:45:43.203 Adding By camera model / class: net.pms.dlna.virtual.MediaLibraryFolder
[main] INFO 19:45:43.203 Adding By ISO settings / class: net.pms.dlna.virtual.MediaLibraryFolder
[main] INFO 19:45:43.203 Adding Photo / class: net.pms.dlna.virtual.VirtualFolder
[main] INFO 19:45:43.203 Adding All Videos / class: net.pms.dlna.virtual.MediaLibraryFolder
[main] INFO 19:45:43.203 Adding HD Videos / class: net.pms.dlna.virtual.MediaLibraryFolder
[main] INFO 19:45:43.203 Adding SD Videos / class: net.pms.dlna.virtual.MediaLibraryFolder
[main] INFO 19:45:43.203 Adding DVD Images / class: net.pms.dlna.virtual.MediaLibraryFolder
[main] INFO 19:45:43.203 Adding Video / class: net.pms.dlna.virtual.VirtualFolder
[main] INFO 19:45:43.203 Adding #- Media Library -# / class: net.pms.dlna.virtual.MediaLibrary
[main] INFO 19:45:43.203 Adding Subtitles / class: net.pms.dlna.virtual.VirtualFolder
[main] DEBUG 19:45:43.203 Search extension for toto.mpg
[main] DEBUG 19:45:43.203 Found 1! net.pms.formats.MPG
[main] INFO 19:45:43.203 Adding A/V sync alternative method / class: net.pms.PMS$3
[main] INFO 19:45:43.203 Adding Default H264 Remux with Mencoder / class: net.pms.PMS$4
[main] INFO 19:45:43.203 Adding Deinterlace Filter / class: net.pms.PMS$5
[main] INFO 19:45:43.203 Adding Definitely disable subtitles / class: net.pms.PMS$6
[main] INFO 19:45:43.203 Adding Auto load .srt/.sub subtitles / class: net.pms.PMS$7
[main] INFO 19:45:43.203 Adding Use ASS default style / class: net.pms.PMS$8
[main] INFO 19:45:43.203 Adding SkipLoopFilter for H264 Decoding [COULD DEGRADE QUALITY] / class: net.pms.PMS$9
[main] INFO 19:45:43.203 Adding Restart HTTP server / class: net.pms.PMS$10
[main] INFO 19:45:43.203 Adding #- Video Settings -# / class: net.pms.dlna.virtual.VirtualFolder
[main] DEBUG 19:45:43.203 Setting DLNA id 0$0 to photos [Gid - 091017]
[main] DEBUG 19:45:43.203 Setting DLNA id 0$1 to Web
[main] DEBUG 19:45:43.203 Setting DLNA id 0$1$0 to Pictures
[main] DEBUG 19:45:43.203 Setting DLNA id 0$1$0$0 to 1257277543171
[main] DEBUG 19:45:43.203 Setting DLNA id 0$1$0$1 to 1257277543171
[main] DEBUG 19:45:43.203 Setting DLNA id 0$1$0$2 to 1257277543171
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$0$3 to Albums
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$0$3$0 to 1257277543171
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$1 to Radios
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$1$0 to JET FM (French Radio)
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$1$1 to Radios With VLC [vlcaudio]
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$1$1$0 to JET FM (French Radio)
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$1$2 to Smooth Jazz
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$1$3 to KBPS All-classical
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$2 to TVs
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$2$0 to France 24
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$2$1 to #--TRANSCODE--#
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$2$1$0 to France 24
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$2$1$0$0 to France 24
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$2$1$1 to BFM TV (French TV)
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$2$1$1$0 to BFM TV (French TV)
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$2$2 to BFM TV (French TV)
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$2$3 to {Tests} FreeboxTV (French Set-top Box) [mplayervideodump]
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$2$3$0 to France 2
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$2$3$1 to #--TRANSCODE--#
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$2$3$1$0 to France 2
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$2$3$1$0$0 to France 2
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$2$3$1$1 to France 2 HD
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$2$3$1$1$0 to France 2 HD
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$2$3$1$2 to Nolife
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$2$3$1$2$0 to Nolife
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$2$3$2 to France 2 HD
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$2$3$3 to Nolife
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$3 to Youtube
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$3$0 to 1257277543187
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$3$1 to 1257277543187
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$3$2 to PS3
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$3$2$0 to 1257277543187
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$3$2$1 to 1257277543187
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$3$3 to Playlist
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$3$3$0 to 1257277543187
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$4 to GameTrailers
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$4$0 to 1257277543187
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$5 to Podcasts
[main] DEBUG 19:45:43.218 Setting DLNA id 0$1$5$0 to 1257277543187
[main] DEBUG 19:45:43.218 Setting DLNA id 0$2 to #- Media Library -#
[main] DEBUG 19:45:43.218 Setting DLNA id 0$2$0 to Audio
[main] DEBUG 19:45:43.218 Setting DLNA id 0$2$0$0 to All Audio Tracks
[main] DEBUG 19:45:43.218 Setting DLNA id 0$2$0$1 to All Audio Playlists
[main] DEBUG 19:45:43.218 Setting DLNA id 0$2$0$2 to By Artist
[main] DEBUG 19:45:43.218 Setting DLNA id 0$2$0$3 to By Album
[main] DEBUG 19:45:43.218 Setting DLNA id 0$2$0$4 to By Genre
[main] DEBUG 19:45:43.218 Setting DLNA id 0$2$0$5 to By Artist/Album
[main] DEBUG 19:45:43.218 Setting DLNA id 0$2$0$6 to By Genre/Artist/Album
[main] DEBUG 19:45:43.218 Setting DLNA id 0$2$0$7 to By Date
[main] DEBUG 19:45:43.218 Setting DLNA id 0$2$0$8 to By Letter/Artist/Album
[main] DEBUG 19:45:43.218 Setting DLNA id 0$2$1 to Photo
[main] DEBUG 19:45:43.218 Setting DLNA id 0$2$1$0 to All Photos
[main] DEBUG 19:45:43.218 Setting DLNA id 0$2$1$1 to By Date
[main] DEBUG 19:45:43.218 Setting DLNA id 0$2$1$2 to By camera model
[main] DEBUG 19:45:43.218 Setting DLNA id 0$2$1$3 to By ISO settings
[main] DEBUG 19:45:43.218 Setting DLNA id 0$2$2 to Video
[main] DEBUG 19:45:43.218 Setting DLNA id 0$2$2$0 to All Videos
[main] DEBUG 19:45:43.218 Setting DLNA id 0$2$2$1 to By Date
[main] DEBUG 19:45:43.218 Setting DLNA id 0$2$2$2 to HD Videos
[main] DEBUG 19:45:43.218 Setting DLNA id 0$2$2$3 to SD Videos
[main] DEBUG 19:45:43.218 Setting DLNA id 0$2$2$4 to DVD Images
[main] DEBUG 19:45:43.218 Setting DLNA id 0$3 to #- Video Settings -#
[main] DEBUG 19:45:43.218 Setting DLNA id 0$3$0 to Subtitles
[main] DEBUG 19:45:43.218 Setting DLNA id 0$3$0$0 to Definitely disable subtitles
[main] DEBUG 19:45:43.218 Setting DLNA id 0$3$0$1 to Auto load .srt/.sub subtitles
[main] DEBUG 19:45:43.218 Setting DLNA id 0$3$0$2 to Use ASS default style
[main] DEBUG 19:45:43.218 Setting DLNA id 0$3$1 to A/V sync alternative method
[main] DEBUG 19:45:43.218 Setting DLNA id 0$3$2 to Default H264 Remux with Mencoder
[main] DEBUG 19:45:43.218 Setting DLNA id 0$3$3 to Deinterlace Filter
[main] DEBUG 19:45:43.218 Setting DLNA id 0$3$4 to SkipLoopFilter for H264 Decoding [COULD DEGRADE QUALITY]
[main] DEBUG 19:45:43.218 Setting DLNA id 0$3$5 to Restart HTTP server
[main] TRACE 19:45:43.218 Scanning network interface lo / MS TCP Loopback interface
[main] TRACE 19:45:43.218 Scanning network interface eth0 / Intel(R) Wireless WiFi Link 5100 - Packet Scheduler Miniport
[main] TRACE 19:45:43.218 Using address /192.168.0.2 found on network interface: name:eth0 (Intel(R) Wireless WiFi Link 5100 - Packet Scheduler Miniport) index: 2 addresses: /192.168.0.2;
[main] TRACE 19:45:43.218 Created socket: /192.168.0.2:5005
[Thread-4] TRACE 19:45:43.234 Starting DLNA Server on host 192.168.0.2 and port 5005...
[main] INFO 19:45:43.250 Using database URL: jdbc:h2:database/medias
[main] TRACE 19:45:43.250 Using database located at : C:\Program Files\PS3 Media Server\database
[main] INFO 19:45:43.625 Database file count: 0
[main] INFO 19:45:43.625 Database version: 1.10.51
[main] TRACE 19:45:43.625 Sending ALIVE...
[main] DEBUG 19:45:43.640 Setting multicast network interface: name:eth0 (Intel(R) Wireless WiFi Link 5100 - Packet Scheduler Miniport) index: 2 addresses:
/192.168.0.2;
[main] DEBUG 19:45:43.640 Sending message from multicast socket on network interface: name:eth0 (Intel(R) Wireless WiFi Link 5100 - Packet Scheduler Miniport) index: 2 addresses:
/192.168.0.2;
[main] DEBUG 19:45:43.640 Multicast socket is on interface: /192.168.0.2
[main] DEBUG 19:45:43.640 Socket Timeout: 0
[main] DEBUG 19:45:43.640 Socket TTL: 32
[main] TRACE 19:45:43.640 Using following UUID: 4c540427-0f9b-3cc9-ba22-3ada2d67d169
[Thread-4] TRACE 19:45:47.359 Receiving a request from: 192.168.0.3
[Thread-11] DEBUG 19:45:47.359 Opened handler on socket Socket[addr=/192.168.0.3,port=56421,localport=5005]
[Thread-11] DEBUG 19:45:47.359 Received on socket: GET /description/fetch HTTP/1.1
[Thread-11] DEBUG 19:45:47.359 Received on socket: Host: 192.168.0.2:5005
[Thread-11] DEBUG 19:45:47.359 Received on socket: Date: Tue, 03 Nov 2009 19:45:34 GMT
[Thread-11] DEBUG 19:45:47.359 Received on socket: User-Agent: UPnP/1.0
[Thread-11] DEBUG 19:45:47.359 Received on socket: X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";
[Thread-11] INFO 19:45:47.390 HTTP: description/fetch / 0-0
[Thread-11] DEBUG 19:45:47.390 Wrote on socket: HTTP/1.1 200 OK
[Thread-11] DEBUG 19:45:47.390 Wrote on socket: Content-Type: text/xml
[Thread-11] DEBUG 19:45:47.390 Wrote on socket: Cache-Control: no-cache
[Thread-11] DEBUG 19:45:47.390 Wrote on socket: Expires: 0
[Thread-11] DEBUG 19:45:47.390 Wrote on socket: Accept-Ranges: bytes
[Thread-11] DEBUG 19:45:47.390 Wrote on socket: Connection: keep-alive
[Thread-11] DEBUG 19:45:47.406 Wrote on socket: Server: Windows_XP-x86-5.1, UPnP/1.0, PMS/1.10.51
[Thread-11] DEBUG 19:45:47.406 Available Content-Length: 1780
[Thread-11] DEBUG 19:45:47.406 Wrote on socket: Content-Length: 1780
[Thread-11] DEBUG 19:45:47.406 Sending stream: 1780 bytes of description/fetch
[Thread-11] DEBUG 19:45:47.406 Close Connection
[main] DEBUG 19:45:48.421 Waiting 250 milliseconds...
[main] TRACE 19:45:48.671 It's ready! You should see the server appears on XMB
[Thread-13] DEBUG 19:45:48.687 Setting multicast network interface: name:eth0 (Intel(R) Wireless WiFi Link 5100 - Packet Scheduler Miniport) index: 2 addresses:
/192.168.0.2;
[Thread-12] TRACE 19:45:58.671 Sending ALIVE...
[Thread-12] DEBUG 19:45:58.687 Setting multicast network interface: name:eth0 (Intel(R) Wireless WiFi Link 5100 - Packet Scheduler Miniport) index: 2 addresses:
/192.168.0.2;
[Thread-12] DEBUG 19:45:58.687 Sending message from multicast socket on network interface: name:eth0 (Intel(R) Wireless WiFi Link 5100 - Packet Scheduler Miniport) index: 2 addresses:
/192.168.0.2;
[Thread-12] DEBUG 19:45:58.687 Multicast socket is on interface: /192.168.0.2
[Thread-12] DEBUG 19:45:58.687 Socket Timeout: 0
[Thread-12] DEBUG 19:45:58.687 Socket TTL: 32
[Thread-13] DEBUG 19:45:58.687 Receiving a NOTIFY from [192.168.0.2:3797]
[Thread-13] DEBUG 19:45:59.562 Receiving a NOTIFY from [192.168.0.2:3797]
[Thread-13] DEBUG 19:45:59.781 Receiving a NOTIFY from [192.168.0.2:3797]
[Thread-13] DEBUG 19:45:59.796 Receiving a NOTIFY from [192.168.0.2:3797]
[Thread-13] DEBUG 19:46:00.500 Receiving a NOTIFY from [192.168.0.2:3797]
[Thread-13] DEBUG 19:46:01.140 Receiving a NOTIFY from [192.168.0.2:3797]
[Thread-13] DEBUG 19:46:01.296 Receiving a NOTIFY from [192.168.0.2:3797]
[Thread-13] DEBUG 19:46:01.578 Receiving a NOTIFY from [192.168.0.2:3797]
[Thread-13] DEBUG 19:46:01.812 Receiving a NOTIFY from [192.168.0.2:3797]
[Thread-13] DEBUG 19:46:01.828 Receiving a NOTIFY from [192.168.0.2:3797]
[Thread-14] DEBUG 19:46:02.359 Opened handler on socket Socket[addr=/192.168.0.3,port=56420,localport=5005]
[Thread-14] DEBUG 19:46:02.359 Received on socket: GET /description/fetch HTTP/1.1
[Thread-14] DEBUG 19:46:02.359 Received on socket: Host: 192.168.0.2:5005
[Thread-14] DEBUG 19:46:02.359 Received on socket: Date: Tue, 03 Nov 2009 19:45:49 GMT
[Thread-14] DEBUG 19:46:02.359 Received on socket: User-Agent: UPnP/1.0
[Thread-14] DEBUG 19:46:02.359 Received on socket: X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";
[Thread-14] INFO 19:46:02.375 HTTP: description/fetch / 0-0
[Thread-14] DEBUG 19:46:02.375 Wrote on socket: HTTP/1.1 200 OK
[Thread-14] DEBUG 19:46:02.375 Wrote on socket: Content-Type: text/xml
[Thread-14] DEBUG 19:46:02.375 Wrote on socket: Cache-Control: no-cache
[Thread-14] DEBUG 19:46:02.375 Wrote on socket: Expires: 0
[Thread-14] DEBUG 19:46:02.375 Wrote on socket: Accept-Ranges: bytes
[Thread-14] DEBUG 19:46:02.375 Wrote on socket: Connection: keep-alive
[Thread-14] DEBUG 19:46:02.375 Wrote on socket: Server: Windows_XP-x86-5.1, UPnP/1.0, PMS/1.10.51
[Thread-14] DEBUG 19:46:02.375 Available Content-Length: 1780
[Thread-14] DEBUG 19:46:02.375 Wrote on socket: Content-Length: 1780
[Thread-14] DEBUG 19:46:02.375 Sending stream: 1780 bytes of description/fetch
[Thread-14] DEBUG 19:46:02.375 Close Connection
[Thread-12] TRACE 19:46:22.000 Sending ALIVE...
[Thread-12] DEBUG 19:46:22.000 Setting multicast network interface: name:eth0 (Intel(R) Wireless WiFi Link 5100 - Packet Scheduler Miniport) index: 2 addresses:
/192.168.0.2;
[Thread-12] DEBUG 19:46:22.000 Sending message from multicast socket on network interface: name:eth0 (Intel(R) Wireless WiFi Link 5100 - Packet Scheduler Miniport) index: 2 addresses:
/192.168.0.2;
[Thread-12] DEBUG 19:46:22.000 Multicast socket is on interface: /192.168.0.2
[Thread-12] DEBUG 19:46:22.000 Socket Timeout: 0
[Thread-12] DEBUG 19:46:22.000 Socket TTL: 32
[Thread-13] DEBUG 19:46:22.000 Receiving a NOTIFY from [192.168.0.2:3942]
[Thread-13] DEBUG 19:46:22.125 Receiving a NOTIFY from [192.168.0.2:3942]
[Thread-13] DEBUG 19:46:22.437 Receiving a NOTIFY from [192.168.0.2:3942]
[Thread-13] DEBUG 19:46:23.078 Receiving a NOTIFY from [192.168.0.2:3942]
[Thread-13] DEBUG 19:46:23.578 Receiving a NOTIFY from [192.168.0.2:3942]
[Thread-13] DEBUG 19:46:24.140 Receiving a NOTIFY from [192.168.0.2:3942]
[Thread-13] DEBUG 19:46:24.609 Receiving a NOTIFY from [192.168.0.2:3942]
[Thread-13] DEBUG 19:46:25.000 Receiving a NOTIFY from [192.168.0.2:3942]
[Thread-15] DEBUG 19:46:25.359 Opened handler on socket Socket[addr=/192.168.0.3,port=56419,localport=5005]
[Thread-15] DEBUG 19:46:25.359 Received on socket: GET /description/fetch HTTP/1.1
[Thread-15] DEBUG 19:46:25.359 Received on socket: Host: 192.168.0.2:5005
[Thread-15] DEBUG 19:46:25.359 Received on socket: Date: Tue, 03 Nov 2009 19:46:12 GMT
[Thread-15] DEBUG 19:46:25.359 Received on socket: User-Agent: UPnP/1.0
[Thread-15] DEBUG 19:46:25.359 Received on socket: X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";
[Thread-15] INFO 19:46:25.375 HTTP: description/fetch / 0-0
[Thread-15] DEBUG 19:46:25.390 Wrote on socket: HTTP/1.1 200 OK
[Thread-15] DEBUG 19:46:25.390 Wrote on socket: Content-Type: text/xml
[Thread-15] DEBUG 19:46:25.390 Wrote on socket: Cache-Control: no-cache
[Thread-15] DEBUG 19:46:25.390 Wrote on socket: Expires: 0
[Thread-15] DEBUG 19:46:25.390 Wrote on socket: Accept-Ranges: bytes
[Thread-15] DEBUG 19:46:25.390 Wrote on socket: Connection: keep-alive
[Thread-15] DEBUG 19:46:25.390 Wrote on socket: Server: Windows_XP-x86-5.1, UPnP/1.0, PMS/1.10.51
[Thread-15] DEBUG 19:46:25.390 Available Content-Length: 1780
[Thread-15] DEBUG 19:46:25.390 Wrote on socket: Content-Length: 1780
[Thread-15] DEBUG 19:46:25.390 Sending stream: 1780 bytes of description/fetch
[Thread-15] DEBUG 19:46:25.390 Close Connection
[Thread-13] DEBUG 19:46:25.828 Receiving a NOTIFY from [192.168.0.2:3942]
[Thread-13] DEBUG 19:46:26.046 Receiving a NOTIFY from [192.168.0.2:3942]
[Thread-10] TRACE 19:46:37.171 Sending BYEBYE...
[Thread-10] DEBUG 19:46:37.171 Setting multicast network interface: name:eth0 (Intel(R) Wireless WiFi Link 5100 - Packet Scheduler Miniport) index: 2 addresses:
/192.168.0.2;
[Thread-10] DEBUG 19:46:37.171 Sending message from multicast socket on network interface: name:eth0 (Intel(R) Wireless WiFi Link 5100 - Packet Scheduler Miniport) index: 2 addresses:
/192.168.0.2;
[Thread-10] DEBUG 19:46:37.171 Multicast socket is on interface: /192.168.0.2
[Thread-10] DEBUG 19:46:37.171 Socket Timeout: 0
[Thread-10] DEBUG 19:46:37.171 Socket TTL: 32
[Thread-13] DEBUG 19:46:37.171 Receiving a NOTIFY from [192.168.0.2:4033]
[Thread-13] DEBUG 19:46:37.359 Receiving a NOTIFY from [192.168.0.2:4033]
[Thread-13] DEBUG 19:46:37.640 Receiving a NOTIFY from [192.168.0.2:4033]
[Thread-13] DEBUG 19:46:37.984 Receiving a NOTIFY from [192.168.0.2:4033]
[Thread-13] DEBUG 19:46:38.187 Receiving a NOTIFY from [192.168.0.2:4033]
[Thread-13] DEBUG 19:46:38.234 Receiving a NOTIFY from [192.168.0.2:4033]
[Thread-13] DEBUG 19:46:38.453 Receiving a NOTIFY from [192.168.0.2:4033]
[Thread-13] DEBUG 19:46:38.562 Receiving a NOTIFY from [192.168.0.2:4033]
[Thread-10] INFO 19:46:38.593 Forcing shutdown of all active processes
[Thread-10] INFO 19:46:38.593 Stopping server on host 192.168.0.2 and port 5005...
[Thread-13] DEBUG 19:45:43.640 Receiving a NOTIFY from [192.168.0.2:3706]
[Thread-13] DEBUG 19:45:43.656 Receiving a NOTIFY from [192.168.0.2:3706]
[Thread-13] DEBUG 19:45:43.734 Receiving a NOTIFY from [192.168.0.2:3706]
[Thread-13] DEBUG 19:45:44.375 Receiving a NOTIFY from [192.168.0.2:3706]
[Thread-13] DEBUG 19:45:45.265 Receiving a NOTIFY from [192.168.0.2:3706]
[Thread-13] DEBUG 19:45:45.406 Receiving a NOTIFY from [192.168.0.2:3706]
[Thread-13] DEBUG 19:45:46.046 Receiving a NOTIFY from [192.168.0.2:3706]
[Thread-13] DEBUG 19:45:46.062 Receiving a NOTIFY from [192.168.0.2:3706]
[Thread-13] DEBUG 19:45:46.750 Receiving a NOTIFY from [192.168.0.2:3706]
[Thread-13] DEBUG 19:45:47.609 Receiving a NOTIFY from [192.168.0.2:3706]
Old 03-11-2009, 10:03 PM   #7
33,222, Level: 44
Activity: 24.6%
OK this section
"[Thread-14] DEBUG 19:46:02.359 Opened handler on socket Socket[addr=/192.168.0.3,port=56420,localport=5005]
Shows PS3MS has seen the PS3 on IP address 192.168.0.3
Can you ping the PS3 from the PC using that IP address?
Double check that there are no firewalls still running. iirc in WinXP you can have firewall's running on Individual network cards.
Also worth trying to run the app with admin rights (if using the run as a service option Change the account the service runs as to a user account with local admin rights instead of the default Local system account.
I'd also have a quick search here as there are posts on an almost daily basis for "PS3/PC not connecting"
Old 03-11-2009, 10:16 PM   #8
4,339, Level: 15
Thanks again - and that link looks useful too.
I don't have access to the PC at the moment.
I'll get back on to it tomorrow.
Cheers, Bob
