External Hard Drive Folder Problem
Old 17-10-2009, 6:20 PM   #1
2,311, Level: 11
Points: 2,311, Level: 11 Points: 2,311, Level: 11 Points: 2,311, Level: 11
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 30, Got 12
I have a WD 1TB USB external hard drive with my movies, pictures, music, etc stored on it
To avoid having to pressing triangle and 'display all' I have renamed the appropriate folders on the external hard drive to MUSIC,VIDEO and PHOTO
However when I connect it the PS3 is still shows the old names of Videos and Pictures - hence it will not access the correct folder. I tried renaming the folders to something completely different and renaming again but it still does not change on the PS3.
Any ideas how I can remedy this?
Old 17-10-2009, 9:33 PM   #2
3,061, Level: 13
Points: 3,061, Level: 13 Points: 3,061, Level: 13 Points: 3,061, Level: 13
Thanks: Gave 22, Got 39
Re: External Hard Drive Folder Problem
Have you tried making new folders and copying everything into them?
Dave Beer (18-10-2009)
Old 18-10-2009, 6:56 PM   #3
2,311, Level: 11
Activity: 0.7%
I guess I was hoping this might have been a known problem with an easier solution.
I'll try with the photos first as I don't fancy having to copy about 400GB of movie files if it won't solve the problem
Dave
Old 18-10-2009, 7:21 PM   #4
33,233, Level: 44
Points: 33,233, Level: 44 Points: 33,233, Level: 44 Points: 33,233, Level: 44
Activity: 20.6%
Activity: 20.6% Activity: 20.6% Activity: 20.6%
Thanks: Gave 527, Got 1,810
Why copy them? Just move them. Creating a new folder and moving the files into it should take seconds
Old 18-10-2009, 10:47 PM   #5
17,360, Level: 31
Points: 17,360, Level: 31 Points: 17,360, Level: 31 Points: 17,360, Level: 31
Activity: 8.3%
Activity: 8.3% Activity: 8.3% Activity: 8.3%
Thanks: Gave 34, Got 809
Or just press 2 extra buttons...
Old 19-10-2009, 12:23 PM   #6
3,061, Level: 13
Yeah i did actually mean move them, silly me.
so, did it work anyway?
Old 19-10-2009, 7:57 PM   #7
2,311, Level: 11
Activity: 0.7%
Aye - cheers
All working okay now
Dave
Old 20-10-2009, 10:06 AM   #8
2,311, Level: 11
Activity: 0.7%
Two extra buttons!
Its triangle,OK,down lots of times, then up a couple of times when I've scrolled down too too far and then OK again on the video folder - not got time for that
Old 20-10-2009, 10:07 AM   #9
17,360, Level: 31
Activity: 8.3%
Surely you still need to scroll etc, even if you've named your folders correctly ?
Old 20-10-2009, 1:45 PM   #10
2,311, Level: 11
Activity: 0.7%
Yep but I don't need to scroll through the root directory first
It is (was) a very trivial thing but was starting to annoy me
Dave
