R:fom2
Old 15-11-2009, 11:38 AM   #1
3,213, Level: 13
Points: 3,213, Level: 13 Points: 3,213, Level: 13 Points: 3,213, Level: 13
Thanks: Gave 6, Got 15
R:fom2
Hi all, never played this game online before but last night was my first time and i have an issue. When i try and play mt character starts going in a circle to the right, when i move it still goes in a circle but not as much. Ive checked all the settings and controls but still doing it, any idea what the cause can be?
Old 15-11-2009, 12:05 PM   #2
RottenFox's Avatar
147,150, Level: 92
Points: 147,150, Level: 92 Points: 147,150, Level: 92 Points: 147,150, Level: 92
Activity: 58.3%
Activity: 58.3% Activity: 58.3% Activity: 58.3%
Thanks: Gave 1,394, Got 2,808
Re: R:fom2
try resetting the controller..you will need a pen, cocktail stick, or toothpick.
its a small button to the right of the screwhole, above the sticker on the rear of the pad.
switch the pad on, and hold down the button for 10 seconds, with the ps3 on.
should do the trick.
if it doesnt, try the reset with the ps3 console off, but the pad attached with the usb cable, then switch on the ps3 using its own on button, the pad should re-pair with the console then.
Old 15-11-2009, 12:31 PM   #3
3,213, Level: 13
Re: R:fom2
ill try that. Only seems to be on that game thou
Old 15-11-2009, 1:44 PM   #4
3,213, Level: 13
Re: R:fom2
ive tryed thisand it has solved the problem, cheers
