GTA4 Switches From 1080p to 720p
Old 25-05-2008, 1:51 PM   #1
2,742, Level: 12
Points: 2,742, Level: 12 Points: 2,742, Level: 12 Points: 2,742, Level: 12
Thanks: Gave 187, Got 76
I bought GTA4 a few days ago, and was wondering when i load the game, the resolution changes from 1080p to 720p. Why is that, do i have to change a setting on the PS3?
The TV i have is a Sonly KDL40V3000, connected with a HDMI cable to my 40gb PS3.
Thank You
Old 25-05-2008, 2:13 PM   #2
zain.786's Avatar
6,023, Level: 18
Points: 6,023, Level: 18 Points: 6,023, Level: 18 Points: 6,023, Level: 18
Thanks: Gave 108, Got 54
Re: GTA4 Switches From 1080p to 720p
Thank You
Try this it should work; Firstly go to to Display Settings then go to Video Output Setttings. Then go on HDMI and go on Custom. Next, 4 boxes will come up untick 720p and 1080i and make sure 1080p's ticked. Then just press X and then click on yes to keep the settings. Should work.
Bauer24 (27-05-2008), Gaspode (30-05-2008)
Old 25-05-2008, 4:02 PM   #3
Master Yoda's Avatar
9,185, Level: 22
Points: 9,185, Level: 22 Points: 9,185, Level: 22 Points: 9,185, Level: 22
Thanks: Gave 19, Got 41
The game actually runs at only 640p, so I wouldn't have thought that forcing it to output 1080p over 720p would make that big a difference (if any at all), but I guess it depends on your TV. Am wondering if this is more a placebo effect than anything else for most people. I would be interested to know if you actually notice any improvement upscaling to 1080p and also if your framerate drops at all as there must be a different hit on the processor upscaling to 1080p instead of 720p...
Old 25-05-2008, 5:24 PM   #4
coluigi's Avatar
4,322, Level: 15
Points: 4,322, Level: 15 Points: 4,322, Level: 15 Points: 4,322, Level: 15
Thanks: Gave 47, Got 89
1080p will be better on the V3000 as it's natively 1080 lines - meaning there's only one layer of upscaling not two.
Old 26-05-2008, 10:46 AM   #5
retro41's Avatar
2,983, Level: 12
Points: 2,983, Level: 12 Points: 2,983, Level: 12 Points: 2,983, Level: 12
Thanks: Gave 13, Got 24
Less judder and blur when I use 1080p, it's actually playable.
720p is unplayable for my eyes.
Old 27-05-2008, 12:53 PM   #6
2,742, Level: 12
Thanks for that, i'm currently playing at 1080p. Not that big a difference though.
Old 27-05-2008, 3:14 PM   #7
5,682, Level: 17
Points: 5,682, Level: 17 Points: 5,682, Level: 17 Points: 5,682, Level: 17
Activity: 46.2%
Activity: 46.2% Activity: 46.2% Activity: 46.2%
Thanks: Gave 35, Got 144
Is it just me or do you get a nasty frame rate hit running it at 1080p?
I have a V3000 btw.
