help with parental controls
Old 03-10-2008, 9:39 PM   #1
2,691, Level: 12
Points: 2,691, Level: 12 Points: 2,691, Level: 12 Points: 2,691, Level: 12
Thanks: Gave 1, Got 3
hi all can anyone help went to put on a kids dvd on the ps2 as i do every day .iv got a problem the parental controls have been set and the kids didnt set it and nether did i .so when it ask for the passcode i dont know it the kids dont know it eather can anyone help as i can reset the ps2 as i dont know how to do this or even if it is possible .thanks
Old 13-10-2008, 5:20 PM   #2
2,577, Level: 11
Points: 2,577, Level: 11 Points: 2,577, Level: 11 Points: 2,577, Level: 11
Thanks: Gave 1, Got 0
Re: help with parental controls
usually the factory setting is 0000 try that , hope it helps
