jap import
Old 03-02-2008, 2:41 PM   #1
1261shaun's Avatar
4,412, Level: 15
Points: 4,412, Level: 15 Points: 4,412, Level: 15 Points: 4,412, Level: 15
Thanks: Gave 9, Got 0
jap import
i have a uk slimline ps2, but would like to import a jap ps2, what kind of problems am i looking at regarding power supply?
Old 10-02-2008, 3:25 PM   #2
3,313, Level: 13
Points: 3,313, Level: 13 Points: 3,313, Level: 13 Points: 3,313, Level: 13
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 5, Got 24
Re: jap import
The slimline PS2s have a separate power supply which, so I've been told by people who've imported them, auto-detect the mains voltage so no step-up/down transformer is needed. All you should require is UK three pin plug/lead to replace the Jap one. Check out the import FAQS etc at:
http://www.ntsc-uk.co.uk
for more detailed info.
Old 14-06-2008, 10:36 PM   #3
3,042, Level: 12
Points: 3,042, Level: 12 Points: 3,042, Level: 12 Points: 3,042, Level: 12
Thanks: Gave 70, Got 128
Smile Re: jap import
any old figure of 8 lead will get it too work
the power supply is external on all but the newest model which is internal, just avoid that one
the PSU is multi voltage and works from 100 - 240 volts, which covers the UK voltage, thats why the 3 pin uk figure of 8 lead works fine
you get can get them pretty cheap nowadays from places like here, ebay or other gaming sites
