Internet Help CF: 3.80 M33-5
Old 19-03-2008, 3:42 PM   #1
1,870, Level: 10
Points: 1,870, Level: 10 Points: 1,870, Level: 10 Points: 1,870, Level: 10
Thanks: Gave 107, Got 51
Hoping someone can help, I tried to connect my cf 3.80 M33-5 to the Intertnet via a wireless connection and all I'm geeting is a SSL handshake error although it used to work fine.
Its not the connection either as other wireless devices work
Old 19-03-2008, 11:38 PM   #2
2,900, Level: 12
Points: 2,900, Level: 12 Points: 2,900, Level: 12 Points: 2,900, Level: 12
Thanks: Gave 6, Got 53
Re: Internet Help CF: 3.80 M33-5
I've read that people who've reported similar problems found that formatting flash1 in recovery might clear things up. I don't know if there's any risk involved since flash1 is just user settings but i'd guess if there was it would be minimal. Before you do it make sure you have a good nand backup though!
HTML code is On
