PSP wallpapers
Old 10-03-2008, 12:12 PM   #1
Urien Rheged's Avatar
13,294, Level: 27
Points: 13,294, Level: 27 Points: 13,294, Level: 27 Points: 13,294, Level: 27
Activity: 13.9%
Activity: 13.9% Activity: 13.9% Activity: 13.9%
Thanks: Gave 375, Got 404
PSP wallpapers
Just bought my 10 year old son a PSP and he wants to change the wallpaper on it. Can anyone tell me how to do this?
I have a PS3, is there a way to download them onto the PS3 and then transfer them to the PSP using Remote Play?
Or can I get them directly from the PSP's internet browser onto the PSP?
Is there any good websites that have free PSP wallpapers?
Old 10-03-2008, 12:35 PM   #2
ja5on's Avatar
Location: close enough to see what Gashead is having for his dinner
12,658, Level: 27
Points: 12,658, Level: 27 Points: 12,658, Level: 27 Points: 12,658, Level: 27
Activity: 22.3%
Activity: 22.3% Activity: 22.3% Activity: 22.3%
Thanks: Gave 863, Got 810
Re: PSP wallpapers
any image as long as its 480x272 will work
You can either upload them onto the psp from a pc, or using the psp browser just search online for the pic you want and save as, then go into the theme settings and set it as wallpaper
http://interfacelift.com/psp/ have a whole section just for psp
Old 10-03-2008, 12:49 PM   #3
13,294, Level: 27
Activity: 13.9%
Re: PSP wallpapers
Thanks.
How do I upload the from a PC onto the PSP?
Old 10-03-2008, 1:00 PM   #4
Scotty's Avatar
8,618, Level: 22
Points: 8,618, Level: 22 Points: 8,618, Level: 22 Points: 8,618, Level: 22
Thanks: Gave 7, Got 423
Re: PSP wallpapers
Originally Posted by R1PLEY View Post
Thanks.
Copy them via a USB cable to the photo folder on the memory stick.
Then go to photo on the XMB select the one you want to view, press triangle for the options and choose set as wallpaper
Old 10-03-2008, 1:12 PM   #5
13,294, Level: 27
Activity: 13.9%
Re: PSP wallpapers
Sorry if I'm sounding thick here, I'm new to the PSP....You mean use the socket on the top of the PSP to connect to a PC? Can I use the PS3's USB cable that connects the PS3's controller to the PS3 when you charge the controller? It has a large normal sized USB plug at one end and one of those small USB plugs at the other end. I used it to pair the PSP to the PS3 when I set up the remote play so I know the plugs fit into the sockets o'k.
I take it the PC will then recognise the PSP is connected to it and you just drag and drop the images from the PC to the PSP?
Old 10-03-2008, 1:17 PM   #6
7,738, Level: 20
Points: 7,738, Level: 20 Points: 7,738, Level: 20 Points: 7,738, Level: 20
Thanks: Gave 371, Got 322
Re: PSP wallpapers
Yes and Yes
Urien Rheged (10-03-2008)
Old 10-03-2008, 1:17 PM   #7
Scotty's Avatar
8,618, Level: 22
Re: PSP wallpapers
That cable sounds like the one you want.
Connect the mini end to the port on the top of the PSP and the std USB to the PC
Set the PSP to USB and the PC should see the memory stick as a removable drive.
Then you just browse drag and drop
Old 10-03-2008, 1:20 PM   #8
13,294, Level: 27
Activity: 13.9%
Re: PSP wallpapers
Thanks to both of you
Is there any websites that have wallpapers that a 10 year would like, e.g. game, movies or cartoon wallpapers?
Old 11-03-2008, 9:37 AM   #9
boltlock's Avatar
4,947, Level: 16
Points: 4,947, Level: 16 Points: 4,947, Level: 16 Points: 4,947, Level: 16
Activity: 19.3%
Activity: 19.3% Activity: 19.3% Activity: 19.3%
Thanks: Gave 179, Got 231
Re: PSP wallpapers
Not specifically for a ten year old but....
http://www.pspwallpapers.com/
http://www.maximumwallpapers.com/
http://www.pspwallpapers4you.com/
....HTH
Urien Rheged (11-03-2008)
HTML code is On
