Wireless
Old 08-03-2008, 10:41 AM   #1
p3L
Posts: n/a
Wireless
How can you disable the wireless function of the PSP? (Like you can do, for example, with a wireless modem-router).
I'm asking this because i believe that the electromagnetical radiation you get with wireless technologies, like Wifi, is dangerous for humans.
The menu of PSP at the Power Saving submenu there is a choice for WLAN energy saving. Is this the answer to what i'm asking?
Old 08-03-2008, 10:44 AM   #2
ja5on's Avatar
Location: close enough to see what Gashead is having for his dinner
12,658, Level: 27
Points: 12,658, Level: 27 Points: 12,658, Level: 27 Points: 12,658, Level: 27
Activity: 22.3%
Activity: 22.3% Activity: 22.3% Activity: 22.3%
Thanks: Gave 863, Got 810
Re: Wireless
errr don't switch it on with the button on the top?
Old 08-03-2008, 2:43 PM   #3
p3L
Posts: n/a
Re: Wireless
There is a button on the left side, above the memory stick slot.
Must i flip it upwards?
Old 08-03-2008, 5:15 PM   #4
ja5on's Avatar
12,658, Level: 27
Activity: 22.3%
Re: Wireless
theres a switch labled 'wlan' on the top, leave it switched to the left
Old 08-03-2008, 5:31 PM   #5
p3L
Posts: n/a
Re: Wireless
Mine has the switch at the left side (on the top there is only the switch that opens the disk drive), but it must be up as the arrow, on the switch, points or down, in order to switch off wifi? Near that switch (on the left), there are 2 leds at the top near the analog stick. I think that the upper led must be on.
Old 09-03-2008, 10:17 AM   #6
WelshBluebird's Avatar
10,786, Level: 24
Points: 10,786, Level: 24 Points: 10,786, Level: 24 Points: 10,786, Level: 24
Thanks: Gave 41, Got 146
Re: Wireless
please say you are kidding lol. We get EM radiation from everything! Even light is EM radiation. The radio waves that are used to broadcast TV and radio are EM waves. I'd imagine if anything, they would have more of an effect on you than the PSP's wifi.
AFAIK, there has be no link proved between EM waves and poor health.
Also, unless you specifically tell it to connect to a network (the green light on the left flashes) then the PSP's wifi is not on at all.
The actual switch however depends on what PSP you have. If you have an older fat one, then its on the left (push the switch up). If you have a newer slim one, then its on the top.
HTML code is On
