Flashing etc
Old 06-03-2008, 1:52 PM   #1
9,587, Level: 23
Points: 9,587, Level: 23 Points: 9,587, Level: 23 Points: 9,587, Level: 23
Thanks: Gave 3, Got 21
Flashing etc
I dont really understand it all but what I do know is my PSP is running 1.5 firmware and devhook 0.46 which allows me to load up to 2.71 firmware. Now I need to go much higher, to 3.90 but dont wanna risk losing the 1.5 altogether and then not being able to go back - is there a way I can just add these more recent firmware editions to devhook 0.46 so i can pick them off a list or do I have to do some complex flashing things? And then if I do flash can I go back??
CK
Old 06-03-2008, 2:31 PM   #2
Scotty's Avatar
8,618, Level: 22
Points: 8,618, Level: 22 Points: 8,618, Level: 22 Points: 8,618, Level: 22
Thanks: Gave 7, Got 423
Re: Flashing etc
CK
Devhook kind of died out with the development of Custom FirmWare. CFW basically replaces the Sony official software with one modified to give you all the things you had under Devhook. If you still need 1.50 support you can with an addon, so you can have best of both worlds.
CFW does require you to re-flash the PSP but with the Pandora method its now a hell of a lot safer than it was when we had to use game exploits.
Old 06-03-2008, 3:39 PM   #3
9,587, Level: 23
Re: Flashing etc
OK i took the risk and am now at ver 3.52 how do I get to 3.90 from here - is there a website you can recommend that makes it easy for me to get from 3.52 to 3.90 CFW? The problem is the few places I have tried say I need 3.52 v4 or summit and I think I only have 3.52 original???
Old 06-03-2008, 4:13 PM   #4
Scotty's Avatar
8,618, Level: 22
Re: Flashing etc
QUOTE=ColdKilla;6568949]OK i took the risk and am now at ver 3.52 how do I get to 3.90 from here - is there a website you can recommend that makes it easy for me to get from 3.52 to 3.90 CFW? The problem is the few places I have tried say I need 3.52 v4 or summit and I think I only have 3.52 original???[/QUOTE]
Is that 3.52 orgianl firmware or custom?
if custom get the software from here
intructions are in each of the downloads
HTML code is On
