PSP connection advice to PS3
Old 05-03-2008, 6:06 PM   #1
4,757, Level: 16
Points: 4,757, Level: 16 Points: 4,757, Level: 16 Points: 4,757, Level: 16
Thanks: Gave 11, Got 7
Hi everyone
Just a quick question I downloaded the gods of war demo from the usa psn network last night but it wouldn't let me downloaded it to my psp because if is registered to my uk ps3 account if i change this to mu usa account can they be changed back and forth.
Old 05-03-2008, 10:04 PM   #2
3,793, Level: 14
Points: 3,793, Level: 14 Points: 3,793, Level: 14 Points: 3,793, Level: 14
Thanks: Gave 14, Got 33
Re: PSP connection advice to PS3
You can change them back and forth - I took the risk and it paid off! The only thing is, when you put the GoW demo on your PSP, you can only play stuff you've downloaded from the US account - for example, I have theme hospital on my UK account, and it wouldnt let me play this after I put GoW on the PSP. All I had to do was connect it to my PS3 again and put theme hospital back on the PSP and it worked ok (but then GoW did not) - so you can only play games from one account at any one time on your PSP. Hope that helps!
Folo30 (06-03-2008)
HTML code is On
