PSP Homebrew Applications and Addons.
Old 26-02-2008, 10:56 AM   #1
SatDude's Avatar
5,946, Level: 18
Points: 5,946, Level: 18 Points: 5,946, Level: 18 Points: 5,946, Level: 18
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 50, Got 36
Lightbulb PSP Homebrew Applications and Addons.
Hi all,
Following a post by Hulligan on the PSP Pandora Kit for AVForums members thread...
Originally Posted by Hulligan View Post
...Now all i need is some homebrew to put on it, any recommendations people?
I decided to start a list of homebrew apps every user can try once the get cfw on their psp’s...
This is what I use at the moment, please add your favorite apps to the list
* LightMP3 2.0.0 Alpha 2 (Light audio player for PSP)
* PSP Filer 4.8 (PSP file management application)
* PSPTube version 20080216 (Lets you view .flv files directly from sites like “YouTube” or “DailyMotion”)
I also use some emus and the Custom Firmware Extender 2.2
You can find all these applications in pspslimhacks.com
Hulligan (26-02-2008)
Old 26-02-2008, 11:14 AM   #2
4,426, Level: 15
Points: 4,426, Level: 15 Points: 4,426, Level: 15 Points: 4,426, Level: 15
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 49, Got 10
Re: PSP Homebrew Applications and Addons.
where do i place emulators on the psp and once i've done that how are they accesible?
Old 26-02-2008, 11:19 AM   #3
SatDude's Avatar
5,946, Level: 18
Activity: 1.0%
Place the emulator in the PSP\GAME folder and access the emulator via the PSP menu under GAME>Memory Stick.
fliegenaffe (26-02-2008)
Old 26-02-2008, 11:25 AM   #4
4,426, Level: 15
Activity: 3.4%
just one more thing,where is the best place to get ALL the emulators from? e.g snes,nes,megadrive,psx etc
Old 26-02-2008, 11:39 AM   #5
SatDude's Avatar
5,946, Level: 18
Activity: 1.0%
Emulators for PSP
Amiga
Arcade Machine Emulators
Atari 2600 Emulator
Atari 800/130XE/5200
Atari Lynx
Commodore 64 / C64
GBA PSP Emulator
MSX PSP Emulator
N64 Emulator
Sam Coupe
Sega CD / Mega CD
Sega Genesis
Sega Saturn
SNES Emulator
NOTE: Some of these emulators might not work with the PSP Slim!
I've tested the SNES, Genesis, and N64 emulators on my PSP Slim and all worked fine, the N64 emulator is a little bit slow.
Old 26-02-2008, 11:39 AM   #6
5,864, Level: 18
Points: 5,864, Level: 18 Points: 5,864, Level: 18 Points: 5,864, Level: 18
Thanks: Gave 186, Got 240
Just installed PSPtube. Something the PSP was really missing imo. Thanks for the link.
After viewing whats available at pspslimhacks, i think im going to need a bigger memory stick, i dont think this 4GB is going to be anywhere near enough!
Old 26-02-2008, 11:41 AM   #7
SatDude's Avatar
5,946, Level: 18
Activity: 1.0%
Hulligan,
I went from a 2GB to 4GB and now i'm on 8GB! Will i ever get a 16GB memory stick???? Not sure!
Old 26-02-2008, 11:52 AM   #8
SatDude's Avatar
5,946, Level: 18
Activity: 1.0%
I also use the Alternative VSHMenu by Red_Squirrel.
What's it?
It is an Alternative VSHMenu that has ALL same functions of the M33 VshMenu and other utilities such as the possibility to change the background color, to power off and to sleep the console, to activate and to disactivate M33 VshMenu from dashboard or to make screenshot of XMB.
Press HOME (by Default) in XMB to start the Alternative VshMenu.
Press CIRCLE (by Default) in Menù to close it.
You can download it from here.
NOTE: For this addon you will have to create a folder called SEPLUGINS on the root of your memorystick and place the addon in this folder, please check the readme file.
Old 26-02-2008, 12:19 PM   #9
5,864, Level: 18
Originally Posted by SatDude View Post
Hulligan,
Think i'll be waiting until the prices drop (a lot!) before i think of getting a 16GB. Do want though!
I noticed on a few homebrew sites that theres some PSP IR stuff so you can control other hardware with the psp, tried installing one but all i got was corrupted data message
Will these work on a Phat PSP, or is it slim only? If you/anyone else uses these that is...
edit - Installed ALT VHS menu, pretty nifty being able to adjust cpu speed on the fly!
Old 26-02-2008, 12:23 PM   #10
SatDude's Avatar
5,946, Level: 18
Activity: 1.0%
IR Stuff doesn’t work with the slim because the slim PSP hasn’t got the infra-red.
All these apps work with the fat/slim PSP. I’ve tested it on my nephew's PSP, basically he has on his fat PSP the same stuff I have on my slim.
Old 01-03-2008, 10:39 PM   #11
SatDude's Avatar
5,946, Level: 18
Activity: 1.0%
PSPTube 20080301 Released
Another update to PSPTube, this time SofiyaCat releases build 20080211. If your unaware, PSP Tube is a Homebrew PSP application that lets users watch Flash movies, Divx movies, YouTube movies from your PSP. The changelog is all in Japanese, but I’m told that this release is a bugfix release. No new features were added.
Old 04-03-2008, 8:16 PM   #12
1,870, Level: 10
Points: 1,870, Level: 10 Points: 1,870, Level: 10 Points: 1,870, Level: 10
Thanks: Gave 107, Got 51
Just downloaded the music player and created a folder on my PSP of the directory PSP\GAME3xx and extracted it here but my music seems to still play on old player am I doing something wrong?
First thing I've tried to do since getting cf.
Old 04-03-2008, 11:26 PM   #13
Scotty's Avatar
8,618, Level: 22
Points: 8,618, Level: 22 Points: 8,618, Level: 22 Points: 8,618, Level: 22
Thanks: Gave 7, Got 423
Place the extracted folder "LightMP3" in the PSP\GAME folder
put your MP3's in a \MUSIC folder on the root of the mem stick
Then in GAME on the xmb run LightMP3
That should be it
crow99 (05-03-2008)
Old 05-03-2008, 1:26 AM   #14
3,196, Level: 13
Points: 3,196, Level: 13 Points: 3,196, Level: 13 Points: 3,196, Level: 13
Thanks: Gave 2, Got 0
Hi I'm looking for some help. I've got 3.71 M33 running on my Slim, I've managed to get Daedalus running but I cant get snes9xTYL 0.4.2 (PSP Slim port) to run. When I put it in the same folder I have Daedalus running from its just showing up as corrupted data any help would be greatly appreciated.
Old 05-03-2008, 7:43 AM   #15
SatDude's Avatar
5,946, Level: 18
Activity: 1.0%
Hi All,
As Scotty said, all these homebrew apps need to be placed in the PSP\GAME folder to work and then in GAME on the xmb run the homebrew app.
Scottish Gear,
I can send you my version of the SNES emulator later today to see if the one i have works...
crow99 (05-03-2008), Scottish Gear (07-03-2008)
Old 05-03-2008, 9:24 AM   #16
3,196, Level: 13
I'm definitely putting it in the right folder because Daedalus is running from there. If you could just point me in the direction of yours I would appreciate it, Would upgrading my firmware to 3.90 make any difference?
Old 05-03-2008, 9:25 AM   #17
1,870, Level: 10
My problem was I was running ZipGenius to uncompress them.
Have since downloaded WinRAR and Uncompress them to my C:\ drive then copy them over to the Memory Stick and all is good thanks to all fopr help
Old 05-03-2008, 1:06 PM   #18
Scotty's Avatar
8,618, Level: 22
No you don't need to upgrade the firmware emulators work on all firmware from 1.5 to 3.9
Get your emulators here
In the download you’ll find a couple of folder make sure you only copy the snes9xTYL folder found in the 3.x folder to x:\PSP\GAME
Old 05-03-2008, 1:38 PM   #19
SatDude's Avatar
5,946, Level: 18
Activity: 1.0%
LightMP3 2.0.0 Alpha 4
Homebrew developer Sakya has updated LightMP3. Light Mp3 is a lightweight audio player for the PSP. His latest release adds shuffle and repeat playback modes and added support for the PSP remote. Plus many bug fixes. See the changelog below:
* Playlist limit raised to 3000 tracks
* Added support for remote control (untested, my remote is broken)
* Fixed many crashes caused by ID3v2 tag reading (mostly cover art)
* Added support for png file for ID3v2’s cover art
* In the Media Library you can now enter a selection, play it or add it to the current playlist (please refer to the README for controls)
* Fixed Shuffle
* Added Shuffle/Repeat play mode
* Faster opening of MP3 file.
Download here!
Old 05-03-2008, 9:14 PM   #20
3,196, Level: 13
Thanks for your help Satdude, Scotty. I've got it running now
Old 19-05-2008, 9:57 AM   #21
12,048, Level: 26
Points: 12,048, Level: 26 Points: 12,048, Level: 26 Points: 12,048, Level: 26
Thanks: Gave 42, Got 92
Hi.. so how well does the n64 emu perform then on the psp ? Is there one yet for mame / neogeo games as well ?
Old 19-05-2008, 10:19 AM   #22
2,900, Level: 12
Points: 2,900, Level: 12 Points: 2,900, Level: 12 Points: 2,900, Level: 12
Thanks: Gave 6, Got 53
Daedalus, the N64 emulator is terrible....the PSP just can't cope with the games being thrown at it. It has a dreadful compatibility with few games which run with any semblance of playability (i've never owned an N64 and played the classics, so these opinions may be a tad harsh and uncoloured by nostalgia).
Just to get you started take a look at CPS1PSP 2.31 for Capcom CPS-1 arcade games, CPS2PSP 2.31 for Capcom CPS-2 arcade games, MVSPSP 2.31 for SNK NeoGeo games and MAME4ALL PSP v4.9r2 HiRes. You may need to do a bit of reading to get these all working. I've experience of the Capcom arcade emulators and they require you to generate a cache file from an original ROM, as i believe does the NeoGeo emu, but with a little reading that's not too hard to set up. Mame i haven't tried...although i see a lot of problems with people using incorrect or incompatible ROM sets.
Old 19-05-2008, 11:45 AM   #23
4,056, Level: 15
Points: 4,056, Level: 15 Points: 4,056, Level: 15 Points: 4,056, Level: 15
Thanks: Gave 2, Got 11
nobody mentioned RACE an Neo Geo pocket color emu that runs near perfect and with a complete rom set only takes around 50MB
Cps1 no cache files needed and ive read that the slim nolonger needs cache files for CPS2
vista/xp on the psp is a fun little try and for what space it takes is worth it just for the flash games.
N64 and Snes emulation can be pretty dissapointing
PSX blew me away and you end up with some good quality low sized games
Old 19-05-2008, 2:07 PM   #24
2,900, Level: 12
Didn't mention it since it's a NeoGeo Pocket emulator. The slim no longer needs to have a cache for the smaller sized CPS2 ROM sets, although it never hurts to generate a cache for every game you try.
Old 19-05-2008, 2:45 PM   #25
11,118, Level: 25
Points: 11,118, Level: 25 Points: 11,118, Level: 25 Points: 11,118, Level: 25
Activity: 15.2%
Activity: 15.2% Activity: 15.2% Activity: 15.2%
Thanks: Gave 195, Got 151
crap, don't even bother to install it! If anything runs at all it feels like it's moving at 1FPS
Old 19-05-2008, 7:02 PM   #26
12,048, Level: 26
Shame
Old 19-05-2008, 8:38 PM   #27
4,056, Level: 15
i get your point but im one of th few that actually liked the system
Old 20-05-2008, 10:30 PM   #28
12,048, Level: 26
So I take it the mvs2psp and cps2psp are pretty stable usable emu's ?
Old 21-05-2008, 7:24 PM   #29
2,900, Level: 12
Very...they're amongst the best.
Old 27-05-2008, 7:20 AM   #30
Kube's Avatar
13,800, Level: 28
Points: 13,800, Level: 28 Points: 13,800, Level: 28 Points: 13,800, Level: 28
Activity: 4.9%
Activity: 4.9% Activity: 4.9% Activity: 4.9%
Thanks: Gave 379, Got 401
PS1 games have really blown me away. A slim PSP and Resident Evil 2 is a match made in heaven, i tells ya!
HTML code is On
