Corrupt File
Old 18-02-2008, 10:38 AM   #1
3,249, Level: 13
Points: 3,249, Level: 13 Points: 3,249, Level: 13 Points: 3,249, Level: 13
Corrupt File
I have tried putting a dvd onto 4gb stick but it comes up as corrupt file, but if i perform same process onto 2gb stick it works fine. I suspect the 4gb is a fake but it shows 3873mb of storage. If it is a fake would it stop me putting dvds onto it?
Old 18-02-2008, 11:52 AM   #2
Scotty's Avatar
8,618, Level: 22
Points: 8,618, Level: 22 Points: 8,618, Level: 22 Points: 8,618, Level: 22
Thanks: Gave 7, Got 423
Re: Corrupt File
I’m afraid the simple answer is yes,
HTML code is On
