PSP and Sky broadband
Old 15-02-2008, 12:55 PM   #1
mrapriliafalco1's Avatar
4,709, Level: 16
Points: 4,709, Level: 16 Points: 4,709, Level: 16 Points: 4,709, Level: 16
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 1, Got 22
does anyone know how to connect a psp with sky broadband as all I ever get is a connection error,do I need to change setting to allow it to share or something as its beyond me
Old 15-02-2008, 1:04 PM   #2
2,721, Level: 12
Points: 2,721, Level: 12 Points: 2,721, Level: 12 Points: 2,721, Level: 12
Thanks: Gave 9, Got 5
Re: PSP and Sky broadband
If it works the same as the ps3, then it should be fairly straight forward:
1. Setup new connection
2. Auto-scan, and select your sky router
3. Input password
4. Enjoy
If this isnt working, then possibly you need to contact sky and ask them? Or possibly try with a different device which isnt a psp?
Old 25-03-2008, 11:49 PM   #3
2,164, Level: 10
Points: 2,164, Level: 10 Points: 2,164, Level: 10 Points: 2,164, Level: 10
Thanks: Gave 2, Got 1
I've had this problem I think with my PS3 and PSP, what I did was go into the router setting on my PC and then tell it to always assign a specific IP address to my PS3 and a different one to the PSP, then I set up tas normal and everythinbg works ok.
Couldn;t get it to work with dynamic IP address.
Good luck
Phil
Old 26-03-2008, 2:48 PM   #4
4,143, Level: 15
Points: 4,143, Level: 15 Points: 4,143, Level: 15 Points: 4,143, Level: 15
Activity: 5.3%
Activity: 5.3% Activity: 5.3% Activity: 5.3%
Thanks: Gave 5, Got 269
My PS3 and PSP connected fine to my sky netgear router. Just do a scan then enter the password, normally all uppercase.
Old 26-03-2008, 4:22 PM   #5
3,161, Level: 13
Points: 3,161, Level: 13 Points: 3,161, Level: 13 Points: 3,161, Level: 13
Thanks: Gave 75, Got 63
I too am having trouble talking to my router. It's not sky broadband but it is a netgear DG834G (which I believe is similar).
Will try using static Ip addresses tonight and may also try changing from WPA to WEP encryption to see if it's something to do with the protocol.
Old 26-03-2008, 9:51 PM   #6
jshippey's Avatar
4,613, Level: 16
Points: 4,613, Level: 16 Points: 4,613, Level: 16 Points: 4,613, Level: 16
Thanks: Gave 13, Got 14
I use my PSP and PS3 wirelessly on our sky broadband with no problems. I have fixed IP's on both and am using WPA. Is it giving you a particular error message? Are other wireless devices working ok?
Old 26-03-2008, 10:37 PM   #7
3,161, Level: 13
Just been aound to my parents house ( to watch the footie) and it connected fine to their sky broadband router. Unfortunately left it round their house which prevents any futher tinkering over here.
Old 19-11-2008, 10:31 PM   #8
2,045, Level: 10
Points: 2,045, Level: 10 Points: 2,045, Level: 10 Points: 2,045, Level: 10
Smile Re: PSP and Sky broadband
I Have had the same Problem?
What you have to do is set the wep index key to 1 on the sky router and then it will work.
Hope this works it did for me then all you have to change are the keys on other wep connections to 1 then everything should work! without turning off the security.
HTML code is On
