Remote play - Error, WLAN disconnected
Old 13-02-2008, 10:42 PM   #1
travid's Avatar
5,844, Level: 18
Points: 5,844, Level: 18 Points: 5,844, Level: 18 Points: 5,844, Level: 18
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 758, Got 436
Just upgraded to 3.90 (thanks Xist)
Trying to connect for remote play to my PS3.
Ive set it up correctly using the correct serial no's (ssid's ?) and RTFM
Will not connect and comming up with the error WLAN disconnected
1. Is this the WLAN of the psp or the ps3.
2. Does it make any differance that I am using a wired connection ie Homeplugs ?
Please forgive if this seems like a silly question and if I havent explained it very well, also my apologies.
Regards
Dave
Old 16-02-2008, 8:27 PM   #2
2,331, Level: 11
Points: 2,331, Level: 11 Points: 2,331, Level: 11 Points: 2,331, Level: 11
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 13, Got 11
Re: Remote play - Error, WLAN disconnected
h there, seen your reply in my thread
Am i right in thinking your not using a wireless router as you have homeplugs? i think you need a wireless network to connect to the ps3 using remote play. This is just a guess but i assume when the ps3 is connected using a wired method the wireless networking part of it is turned off.
So to connect to the ps3 you would need a wireless router that is also connected to the home plugs, so the psp can connect to the router (via wireless) then the router would connect to the homeplugs, then the homeplugs would connect to the ps3.
bare in mind this is just a guess.....
also ssid's are the name of the name of a wireless network, since you dont know this it makes me wonder about you having a wireless network
Last edited by radical ed; 16-02-2008 at 8:31 PM. Reason: added more for clarity...
travid (17-02-2008)
Old 17-02-2008, 5:33 PM   #3
travid's Avatar
5,844, Level: 18
Activity: 3.0%
also ssid's are the name of the name of a wireless network, since you dont know this it makes me wonder about you having a wireless network[/QUOTE]
Thanks for the first part of your reply Ed, but I'm not sure what you mean about your wondering about my wireless network ?
Its just that the drop outs were so frequent and the signal strength so poor that I opted for home plugs.So I use my wireless modem router as a hub for my homeplug set up.
SSID's, I thought they were Russian Subs !
Old 17-02-2008, 9:11 PM   #4
2,331, Level: 11
Activity: 0.7%
i just ment that i wasnt sure you had a wireless router, maybe just a normal one. so you do have a wireless router?
i think what you need to do, is connect the psp to the wireless router, then the signal should go down the homeplugs....maybe......
travid (18-02-2008)
Old 17-02-2008, 9:59 PM   #5
derek1971's Avatar
7,395, Level: 20
Points: 7,395, Level: 20 Points: 7,395, Level: 20 Points: 7,395, Level: 20
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 179, Got 271
i take it you have the wlan switch turned on on the psp. it took me a couple of goes before i realised ihad it turned off
travid (18-02-2008)
Old 18-02-2008, 5:47 PM   #6
travid's Avatar
5,844, Level: 18
Activity: 3.0%
You cant be as dull as me Derek and to confirm this fact, how do you check the wlan switched on ? and thanks for the support !
Thanks for the reply Rd and the clarification.I will try this and see if this flippin works
Old 19-02-2008, 12:26 AM   #7
derek1971's Avatar
7,395, Level: 20
Activity: 1.0%
on the slim and lite it is a switch on the top of the psp - slide it to the right to turn wlan on - not sure where it is is you have the old model.
travid (20-02-2008)
HTML code is On
