First upgrade to 3.71 M33-4, then since it's a fat psp Install the 1.50 kernel add-on (version 2). Now which version of Hellcat's pandora installer are you using? If you're not using revision 3 get it
here and read the readme.
Excerpt from readme:
To use the installer, first you need the 1.50 updater EBOOT named
as "UPDATE.PBP" in the root folder of your memorystick.
As a regular Pandora user you'll have that already, if not copy it!
Now copy the "pan3xx" folder from this archive to
/PSP/GAME/ on your memorystick - and run it!
1.50 eboot is available
here if you haven't already got it.
Then you just hit square to restore the battery to normal, or R plus the circle button to restore it using the serial number taken from your eeprom (if you backed it up prior to pandora-ing it)
