3.71 M33-2 to 3.9 ?
Old 10-02-2008, 6:53 PM   #1
hillbilly1's Avatar
2,256, Level: 11
Points: 2,256, Level: 11 Points: 2,256, Level: 11 Points: 2,256, Level: 11
Thanks: Gave 10, Got 7
3.71 M33-2 to 3.9 ?
I am trying to put the latest "custom" firmware on my brothers PSP. as per tilte he is on 3.71. when I try to upgrade to 3.8 I get the message "this program can only be executed on a 3.80 M33, when I try to go direct to 3.9 it says 390.PBP does not exist! what am I doing wrong ?
Old 10-02-2008, 7:50 PM   #2
5,146, Level: 16
Points: 5,146, Level: 16 Points: 5,146, Level: 16 Points: 5,146, Level: 16
Thanks: Gave 151, Got 24
Re: 3.71 M33-2 to 3.9 ?
Originally Posted by hillbilly1 View Post
imo stick to 3.71 M33 just yet, most stable & alot more going for it then all others, there also some bugs in later version's, get update 4 for it, that should run all you want, unless you want radio for your slim, even so there problems there.
just my opinion.
doodles
Old 10-02-2008, 8:16 PM   #3
hillbilly1's Avatar
2,256, Level: 11
Hi Doodles,
how did you know it was a slim ??!!
just put update 4 on it , no problems, and if it runs all the games he will be happy!
many thanks!
Old 11-02-2008, 1:08 AM   #4
Thanks: Gave 88, Got 75
I agree....
3.71 all the way...
Don't think its going to be worth upgrading until 4.00 at least, nothing to gain apart from gimmicks.
HTML code is On
