Help PC says I need PSP Type A driver to install on my PC - Vista problem ?
Old 20-06-2007, 12:57 PM   #1
jamieuk23's Avatar
13,200, Level: 27
Points: 13,200, Level: 27 Points: 13,200, Level: 27 Points: 13,200, Level: 27
Thanks: Gave 184, Got 29
Hi Just got my PSP which I bought from my mate. when I connect it via usb to my PC I get this message.
"windows need to install driver software for your psp type A"
I choose the option "locate and install driver software (recommended)
but it doesn't find the driver and my PSP wont connect. do I need a driver for my PSP or should it work with out one ??
any help is appreciated ! running on vista
thanks
Old 27-01-2008, 12:10 AM   #2
29,688, Level: 42
Points: 29,688, Level: 42 Points: 29,688, Level: 42 Points: 29,688, Level: 42
Activity: 7.6%
Activity: 7.6% Activity: 7.6% Activity: 7.6%
Thanks: Gave 41, Got 207
Re: Help PC says I need PSP Type A driver to install on my PC - Vista problem ?
http://teknobabble.wordpress.com/200...er-a-solution/
Old 09-08-2008, 1:36 PM   #3
2,304, Level: 11
Points: 2,304, Level: 11 Points: 2,304, Level: 11 Points: 2,304, Level: 11
i have the same problem as you but i'm running on windows xp professional is there anyone out there that can help?????????????
Old 17-06-2009, 1:54 PM   #4
1,616, Level: 9
Points: 1,616, Level: 9 Points: 1,616, Level: 9 Points: 1,616, Level: 9
The Site referred to by Meansizzler has now moved to :
Technobabble » Blog Archive » Vista Driver Problems installing a USB Media Reader – A solution!
It should help if you are trying to instal a USB driver.
HTML code is On
