PSP Go Video
Old 14-02-2010, 5:45 PM   #1
Thanks: Gave 3, Got 10
PSP Go Video
What format of movie do I need to have to watch it on the PSPgo.
I plan on putting some movies onto the M2 card, to view from that. I tried converting a DVD, and then copying onto card using USB and card reader, but it did not work.
I am not sure of anything in regards to this.
Any help is appreciated.
Mark
Old 14-02-2010, 6:20 PM   #2
Illustrious Member
BenchyUK's Avatar
47,248, Level: 53
Points: 47,248, Level: 53 Points: 47,248, Level: 53 Points: 47,248, Level: 53
Activity: 47.3%
Activity: 47.3% Activity: 47.3% Activity: 47.3%
Thanks: Gave 395, Got 933
I'd like to know too cos ones i have on my PS3 Hard Drive wont play on the PSP like i thought they would
Old 18-02-2010, 6:48 PM   #3
F-Stop's Avatar
1,874, Level: 10
Points: 1,874, Level: 10 Points: 1,874, Level: 10 Points: 1,874, Level: 10
Thanks: Gave 62, Got 27
Thumbs up
I've transfered several music videos from my iphone to my Go via the Media Go software and they were all in MP4 format...and they look really good too
Old 18-02-2010, 9:34 PM   #4
caster troy's Avatar
3,376, Level: 13
Points: 3,376, Level: 13 Points: 3,376, Level: 13 Points: 3,376, Level: 13
Thanks: Gave 5, Got 10
Re: PSP Go Video
Use pspvideo9 make sure that your pspgo is connected to your pc as it won't work. But it's very good. If you want to rip DVDs try dvdshrink. Just google it
Sent from my iPod touch using Tapatalk
HTML code is On
