i have more than 1 psp go, can i use the free game codes on the same account?
Old 13-01-2010, 2:14 PM   #1
FKA FKA is offline
1,954, Level: 10
Points: 1,954, Level: 10 Points: 1,954, Level: 10 Points: 1,954, Level: 10
Thanks: Gave 11, Got 16
as title says, i dont wanna get banned but i legally have 4 psp gos in total and ally my family use the same account, so can i use the free game codes (the coice between assaassins creed, motorstorm and gt) and we also all had the old psps so can i use the umd upgrade scheme and get 12 games from that on the same account?
Old 13-01-2010, 3:07 PM   #2
3,540, Level: 13
Points: 3,540, Level: 13 Points: 3,540, Level: 13 Points: 3,540, Level: 13
Thanks: Gave 76, Got 40
You only get one code (from the choice of 3) if using a different account for each psp go.
The old umd scheme is the same.
You can use the same account on multiple Go's, so at least when purchasing a game from the psn store, you can then use it on all 4.
HTML code is On
