PSP Go Help
Old 09-01-2010, 1:32 PM   #1
Thanks: Gave 3, Got 10
PSP Go Help
Got the son a PSP Go to use with his PS3.
Now I have registered everything, and the PSP Go is accessing Store, PSN etc.
But when I try to get it connected for remote play the following comes up
'There is a DNS error ( 80410410)
Any advise?
Also, any advise on what he can do with the PSP
Thanks again
Old 09-01-2010, 4:04 PM   #2
3,540, Level: 13
Points: 3,540, Level: 13 Points: 3,540, Level: 13 Points: 3,540, Level: 13
Thanks: Gave 76, Got 40
Any advise?
Thanks again
I think it is a communication error. I would try deleting the connection (on the psp) and retrying it
Old 07-02-2010, 3:15 PM   #3
rewari007's Avatar
1,206, Level: 7
Points: 1,206, Level: 7 Points: 1,206, Level: 7 Points: 1,206, Level: 7
Thanks: Gave 2, Got 1
is your problem fixed or you need some more suggestion... I can help you if needed...
Old 07-02-2010, 6:16 PM   #4
It is working most of the time now tbh, but any more advise is appreciated.
Mark
HTML code is On
