psp 3.03
Old 13-11-2009, 9:30 PM   #1
4,671, Level: 16
Points: 4,671, Level: 16 Points: 4,671, Level: 16 Points: 4,671, Level: 16
Thanks: Gave 3, Got 2
psp 3.03
hi guys any help would b gr8
went from 2.82 up to 3.03 and then tried downgrading to 1.50 i get the red xyz file but when click it says the game could not b started 80020148
is this easy fix ?
or anyone know a good file to use so H.B can b played or good walk through ?
or good file to use ....i have gta liberty city game with 2.0 version
cheers jas
Old 21-11-2009, 11:46 PM   #2
1,399, Level: 8
Points: 1,399, Level: 8 Points: 1,399, Level: 8 Points: 1,399, Level: 8
Thanks: Gave 0, Got 4
Is the 3.03 CFW (Custom FW) or OFW (Official FW).
Check in your system settings / system information option. I think the 3.03 was called something like 3.03 OE.
In any case it seems you cannot load the xyz file because you do not have CFW on your psp. Use the following tutorial:
Article Detail - PlayStation Portable News - PSP Updates
I would recommend after doing all those steps to install the most recent CFW (5.50 GEN-D2).
Also I recommend using the following for a more foolproof way to update your PSP after downgrading it to 1.50:
[Tutorial] Hellcat's CFW Recovery Flasher (1.50) - PSP Hacks - Forums
Good luck, it might seem confusing but should be straightforward!
HTML code is On
