runds in my wallet
Old 02-11-2009, 3:07 PM   #1
2,505, Level: 11
Points: 2,505, Level: 11 Points: 2,505, Level: 11 Points: 2,505, Level: 11
Activity: 11.0%
Activity: 11.0% Activity: 11.0% Activity: 11.0%
Thanks: Gave 31, Got 5
runds in my wallet
hi there ive got funds burning a hole in my wallet can anyone recommend any games, ive just bought china town wars and was looking at motor storm artic edge
Old 02-11-2009, 5:05 PM   #2
Tonks01's Avatar
11,119, Level: 25
Points: 11,119, Level: 25 Points: 11,119, Level: 25 Points: 11,119, Level: 25
Thanks: Gave 98, Got 211
Re: runds in my wallet
Oooooh FUNDS, wondered what this was going to be about
Good start with China Town Wars Motorstorm has been well received and if youre a fan of it's console counterpart I'm sure you will get on great.
That being said, if your patient were on the cusp of some really good games being released. LittleBigPlanet, Assassins Creed, Jak & Daxter, Fat Princess among others. Probably the strongest release window since the PSP came out.
Old 03-11-2009, 1:15 PM   #3
2,505, Level: 11
Activity: 11.0%
Sorry i couldnt edit the title once its has been posted. Do you have any ideas when those games you mentioned are released
Old 03-11-2009, 2:17 PM   #4
Tonks01's Avatar
11,119, Level: 25
LittleBigPlanet : 20th Nov
Jak & Daxter : 20th Nov
Assassins Creed : Bloodlines : 20th Nov
Some others :
Formula 1 2009 : 20th Nov
Ghostbusters : 6th Nov
Not got a date on Fat Princess at the moment, but it appears alot is coming out on the 20th of this month (although I assume they will come to the store on the 19th)
Also a bunch of Demos on the store, if you have a PS3 create a US account and download some demos from their store, got quiet a bit more than the UK one.
Old 04-11-2009, 7:38 AM   #5
Kube's Avatar
13,800, Level: 28
Points: 13,800, Level: 28 Points: 13,800, Level: 28 Points: 13,800, Level: 28
Activity: 4.9%
Activity: 4.9% Activity: 4.9% Activity: 4.9%
Thanks: Gave 379, Got 401
Cant wait for LittleBig Planet, should really suit the PSP.
Old 04-11-2009, 9:17 AM   #6
2,505, Level: 11
Activity: 11.0%
thanks for the help guys think ill wait and see what the 20th brings
HTML code is On
