Playing avi files on a PSP
Old 19-10-2009, 1:49 PM   #1
Sick Boy's Avatar
4,885, Level: 16
Points: 4,885, Level: 16 Points: 4,885, Level: 16 Points: 4,885, Level: 16
Activity: 5.7%
Activity: 5.7% Activity: 5.7% Activity: 5.7%
Thanks: Gave 38, Got 62
Aside from conversion to an MP4 file. Can the PSP play these files using some kind of CFW or am I being naive?
The PS3 can play them, my creative can play them, but the PSP can't. I love the screen on the PSP but the conversion times are just way too long to make it worthwhile for day to day use.
Old 19-10-2009, 6:47 PM   #2
10,643, Level: 24
Points: 10,643, Level: 24 Points: 10,643, Level: 24 Points: 10,643, Level: 24
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 277, Got 109
Re: Playing avi files on a PSP
I am not sure what the capabilities are as I only just got a 2nd hand psp, but mine plays avi files if I use remote play, but maybe the PS3 is doing the work there?
Old 04-11-2009, 11:05 PM   #3
jfish
Posts: n/a
only way I have managed to play AVI on PSP is via PimpStreamer - its a PSP and Windows application to stream video content to the PSP over wifi
you run PIMPStreamer on a Windows machine and point to your media files then run Pimp on the PSP which connects to the PC and you select the media file and play it.
Old 08-11-2009, 6:58 PM   #4
1,399, Level: 8
Points: 1,399, Level: 8 Points: 1,399, Level: 8 Points: 1,399, Level: 8
Thanks: Gave 0, Got 4
Only long and tedious ways which require streaming from another source. The PSP itself does well with MP4's though. There are loads of sites where you can find VERY good quality MP4 stuff...
Old 17-11-2009, 3:27 PM   #5
2,558, Level: 11
Points: 2,558, Level: 11 Points: 2,558, Level: 11 Points: 2,558, Level: 11
Thanks: Gave 0, Got 17
Yup, and the same videos can generally be played on PSP/iPod/Zune (and thats what to search for on t'internet).
HTML code is On
