Need to extend PSP 3000 av component lead.
Old 17-10-2009, 10:30 PM   #1
1,397, Level: 8
Points: 1,397, Level: 8 Points: 1,397, Level: 8 Points: 1,397, Level: 8
Question Need to extend PSP 3000 av component lead.
I have just brought a psp 3000 and an accessory pack that had an av component lead (the one with five plugs on the end) in. the problem is the lead is not long enough to each where i sit. i have been looking on the web and i can not find an extentiion cable with the five plugs on only ones with just three on (red/blue/green). where can i get an extention? would it work if i used a rgb component extention and a seperate red/white av extension?
thanks for reading this
Dave
Old 18-10-2009, 7:10 PM   #2
45,504, Level: 52
Points: 45,504, Level: 52 Points: 45,504, Level: 52 Points: 45,504, Level: 52
Activity: 19.3%
Activity: 19.3% Activity: 19.3% Activity: 19.3%
Thanks: Gave 378, Got 854
Re: Need to extend PSP 3000 av component lead.
standard phono extensions should work - its not HD or anything. so three sets of stereo phono extenders from maplins would do
Old 18-10-2009, 10:13 PM   #3
1,397, Level: 8
Lightbulb Re: Need to extend PSP 3000 av component lead.
Thanks for the advice. have found a component av switch box on amazon for £30 so will give it a try. As i only have one component conection on my tv this way i will be able to plug both the psp lead and my wii lead in and will also be able to plug my gamecube into it,
thanks again
dave
P.S. will post to let say wether the switch box works.
HTML code is On
