PSP Battery - where can I buy a replacement?
Old 17-10-2009, 10:17 AM   #1
1,983, Level: 10
Points: 1,983, Level: 10 Points: 1,983, Level: 10 Points: 1,983, Level: 10
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 28, Got 22
I need a new battery for a psp phat
I know there are loads on ebay but I'm wary of ending up with a fake
Can anyone tell me where I can buy either an official replacement battery or a good quality 3rd party replacement?
Old 17-10-2009, 10:31 AM   #2
15,585, Level: 30
Points: 15,585, Level: 30 Points: 15,585, Level: 30 Points: 15,585, Level: 30
Activity: 16.5%
Activity: 16.5% Activity: 16.5% Activity: 16.5%
Thanks: Gave 1,045, Got 784
Re: PSP Battery - where can I buy a replacement?
Play.com (UK) : Official Sony PSP Battery Pack : Playstation Portable
Check here, dont worry about play trade it's often similar to amazon and u get new ( had few pc games off it sealed) Cheap too.
Go with good feedback and u be fine. Yeah i wouldn't go ebay either.
Old 27-11-2009, 8:04 PM   #3
Johnmcl7's Avatar
6,730, Level: 19
Points: 6,730, Level: 19 Points: 6,730, Level: 19 Points: 6,730, Level: 19
Activity: 22.3%
Activity: 22.3% Activity: 22.3% Activity: 22.3%
Thanks: Gave 48, Got 328
I've been trying to find an official one as well, the Play entry doesn't look particularly convincing - the comment on the main item is 'Not official version 3rd party, will still fit, and function perfectly.'
If anyone has received a genuine battery it would be useful to know which Playtrade seller it came from or any other possible source.
John
HTML code is On
