Help a newbie to mod a psp
Old 15-10-2009, 9:06 AM   #1
1,846, Level: 9
Points: 1,846, Level: 9 Points: 1,846, Level: 9 Points: 1,846, Level: 9
Thanks: Gave 2, Got 2
Hi guys
recently bought a psp slim 2003 from heliocentric in the classified
anyways can someone point me in the right direction to
  • determine if my psp moddable
  • what firmware can be used and do i have to do it in steps etc
  • do i need a pandora
Old 15-10-2009, 10:14 AM   #2
Sick Boy's Avatar
4,885, Level: 16
Points: 4,885, Level: 16 Points: 4,885, Level: 16 Points: 4,885, Level: 16
Activity: 5.7%
Activity: 5.7% Activity: 5.7% Activity: 5.7%
Thanks: Gave 38, Got 62
Re: Help a newbie to mod a psp
I will follow with interest as my PSP is a 2003 with date 8C and firmware 6.10 (as is yours i believe) and I didn't think they were hackable.
I think you will definetly need the pandora though as you need to backdate the firmware. I think mine shipped with 3.95 or 4.01 but I can't be sure as bought it second hand.
Old 15-10-2009, 10:36 AM   #3
1,846, Level: 9
my system software is 6.10
Old 15-10-2009, 12:39 PM   #4
5,110, Level: 16
Points: 5,110, Level: 16 Points: 5,110, Level: 16 Points: 5,110, Level: 16
Activity: 0.6%
Activity: 0.6% Activity: 0.6% Activity: 0.6%
Thanks: Gave 33, Got 102
Can your PSP have Custom Firmware installed? - Atma Xplorer
Have a read through this to see if it is possible to install cfw on your psp. If you can then you will need a pandora battery and magic memory stick as you can't use the chickhen method.
Old 17-10-2009, 11:01 AM   #5
Scotty's Avatar
8,618, Level: 22
Points: 8,618, Level: 22 Points: 8,618, Level: 22 Points: 8,618, Level: 22
Thanks: Gave 7, Got 423
if its hack able see post above, you will need a Pandora battery or Datel Tool these are widely available off the net, a magic memory stick which you can create yourself with a standard memory stick pro duo and a bit of software called "Rain's ultralight MMS"
I can PM you a step by step guide if you need one
Old 17-10-2009, 1:48 PM   #6
1,982, Level: 10
Points: 1,982, Level: 10 Points: 1,982, Level: 10 Points: 1,982, Level: 10
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 28, Got 22
i have a slim psp with OFW 6.10 and 8C and its non hackable
there away to tell if you have the v3 motherboard and are on 6.10 but you need a psp running CFW to create some files on the memory stick
Old 17-10-2009, 1:57 PM   #7
Scotty's Avatar
8,618, Level: 22
you don't need a PSP with CFW to create a magic Memory stick, just use something like "Rain's ultralight MMS"
Old 17-10-2009, 4:23 PM   #8
1,982, Level: 10
Activity: 1.5%
i didn't mean to create a magic memory stick i meant a stick to test whether CFW can be installed
there is a guide where u put a 3.90 and a 4.05 file on the memory stick and use getipl program and this way you can identify if your motherboard is an unhackable ta-088 V3 and you need a CFW psp to do this
here is the guide
http://www.consolespot.net/forums/ps...dentifier.html
i tried this and it confirmed I have a v3 mobo
Old 17-10-2009, 4:46 PM   #9
Scotty's Avatar
8,618, Level: 22
here is the guide
bad news!
HTML code is On
