Originally Posted by bbasra Thanks for the reply however, i'm still confused. Sorry.
Isn't 5.50 GEN-D the latest version and do i need to use pandora battery? |
As has been said, you only need a Pandora if the PSP is on original Sony software.
You can't go straight to latest GEN-D2 firmware, you need to update to the one of the newer M33’s then you can update to GEN-B2 and then to GEN-D and finally GEN-D2
Originally Posted by snooper Hi Scotty sorry not replied sooner had net access probs. The psp i tried it on was one already flashed and updated to 5.50genD2. Can you only flash with magic mem/pandora on an unflashed psp or try what i put in previous post. No lights appeared & got no response, just a black screen also tried on my mates, same symptoms but his was also a 5.50genD2. I used xp and the card is a proper sony 1gb, when trying to make it everything went fine and said mms ok at end of the procedure. Any thoughts and once again thanks pal. |
Very odd, the Pandora and MMS should work on any of the flashable PSP's.
If the orange memory stick light doesn't flash then its not finding the IPL (boot) sector on the memory stick
If the green light doesn't light then the battery isn't charged or not recognised
Is the Pandora battery an off the shelf product (Datel tool)?
Do you have another memory stick pro duo less than 4GB, if so try formatting it on you PC before you build the MMS
