psp slim datel tool
Old 09-10-2009, 4:17 PM   #1
7,284, Level: 20
Points: 7,284, Level: 20 Points: 7,284, Level: 20 Points: 7,284, Level: 20
Thanks: Gave 153, Got 41
psp slim datel tool
Firstly , i am a total noob with this cfw stuff, so apologies if nothing makes sense.I have a psp slim with the firmware 5.0.After reading about cfw and the possibiliy of backing up umd's,i ordered a datel service tool and 4gb card.The problem i have is that the datel tool isnt showing on the psp so i can charge it ready for use.I was wondering if the 5.0 firmware has blocked the tool or the battery is a duffer.
Old 10-10-2009, 9:19 AM   #2
Scotty's Avatar
8,618, Level: 22
Points: 8,618, Level: 22 Points: 8,618, Level: 22 Points: 8,618, Level: 22
Thanks: Gave 7, Got 423
Re: psp slim datel tool
datel tool is only half of the requirements, you'll also need a magic memory stick, a standard memory stick with special software to reflash it with cfw
i'll pm you the details
spocktra (10-10-2009)
HTML code is On
