Replacement shell..where from and easy to do?
Old 17-08-2009, 1:59 PM   #1
MacReady's Avatar
14,071, Level: 28
Points: 14,071, Level: 28 Points: 14,071, Level: 28 Points: 14,071, Level: 28
Thanks: Gave 218, Got 61
My sons PSP fat has finally decided to die (or rather the battery has) so I have said I will order a new battery and, at the same time, get him a complete new shell/fascia/button set to make it look all shiny and new ;-)
Can anyone recomend the best place to get these from though...there seems to be loads on Ebay but it's hard to tell what the quality is like. I would ideally like something that is as close to the original shell quality as possible.
Thanks in advance :-)
Old 24-08-2009, 1:01 PM   #2
6,588, Level: 19
Points: 6,588, Level: 19 Points: 6,588, Level: 19 Points: 6,588, Level: 19
Thanks: Gave 516, Got 76
Re: Replacement shell..where from and easy to do?
Hi! I just got a new top fascia from ebay from the seller - is.it.here.already!
And it is very good quality! - You don't get new buttons, just the fascia. Next day delivery as well.
I followed this tutorial - PSP Repair Information
Was done in 20 minutes. Get some alcohol wipes to clean it when it's apart.
Good luck. Any problems ask away!
HTML code is On
