13-05-2009, 3:10 PM
#1 (permalink)
| | Senior Member
Thanks: Gave 18, Got 56 | Optoma HD700X - Part 2
( mod edit...Hi, please use this thread as a continuation of the HD700X thread which can be found here....Optoma HD700X )
Received my projector & mount today from play & ebay respectively, screen must be coming on a different delivery
13-05-2009, 6:06 PM
#2 (permalink)
| | Member
Thanks: Gave 4, Got 5 | Re: Optoma HD700X Quote:
Originally Posted by monkey00 Received my projector & mount today from play & ebay respectively, screen must be coming on a different delivery | When I received my play order, the screen was delivered separately by another company. Strangely the screen came first.
I was excited as a two year old and the wife even thinks it was money well spend |
13-05-2009, 6:50 PM
#3 (permalink)
| | Member
Thanks: Gave 31, Got 26 | Re: Optoma HD700X Quote:
Originally Posted by monkey00 Received my projector & mount today from play & ebay respectively, screen must be coming on a different delivery | Play should have contacted you to confirm a delivery date for the screen!
Here are a few pictures of the 82" 16:9 screen from Play.com! You'll probably be gettin' the 92" version!
13-05-2009, 11:38 PM
#4 (permalink)
| | Member
Thanks: Gave 28, Got 38 | Re: Optoma HD700X
Received my projector mount on tuesday, projector on wednesday and hoping for the screen today (thursday) along with my 15m HDMI cable.
I also ordered the play package.
Found it strange that they would send them out by different couriers. Surely its obvious you would want it all at the same time. haha
Was really surprised at how small it was aswell!
Not what i expected but its better as not such an eyesore.
__________________ Sony KDL-26T3000 - Optoma HD700X - Sony DAV-DZ260 - Sony PS3 40GB - Acer 3004WLMi Laptop - Asus Eee PC 1000H - Sony A200 + 18-70mm kit lens |
14-05-2009, 2:25 PM
#5 (permalink)
| | Senior Member
Thanks: Gave 18, Got 56 | Re: Optoma HD700X
Yea someone called from Play yesterday about the screen, apparently its coming tomorrow.
I had a few games of Xbox FIFA 09 on this last night, all i can say is that it was AMAZING! i couldn't believe the quality
Ill report back when ive got the screen mounted as im sure ill have a hundred questions!
First off... is it best to mount the screen of the PJ first? |
14-05-2009, 4:28 PM
#6 (permalink)
| | Member
Originally Posted by monkey00 First off... is it best to mount the screen of the PJ first?  | It all depends! It's alot easier to move the Pj around if in the wrong place then having to reposition the screen! It's big and heavy!
Firstly, you'll need to know roughly where you're going to project the image! Remember that the Pj has to be pretty much in the centre of the screen!
Second, you need to know where your ceiling joists are when mounting the Pj! I would'nt know about plaster board?
I had a hand from my uncle when mounting the screen on the wall! Two people make it so much easier!
Even still, my image slants slightly at the bottom left corner where the Pj is'nt level!
Hope this helps!
14-05-2009, 8:48 PM
#7 (permalink)
| | Member
Thanks: Gave 28, Got 38 | Re: Optoma HD700X - Part 2
Well thought the screen would be coming today. I was wrong. But my HDMI cable came. Really hoping the screen comes tomorrow though so i have it for the weekend.
Play didnt contact me though about a delivery date...
14-05-2009, 10:45 PM
#8 (permalink)
| | Distinguished Member
Thanks: Gave 124, Got 980 | Re: Optoma HD700X - Part 2
I finally put an offer for a proper screen on ebay. Just waiting for it to be accepted. It is electric and should be the same 80" size to what I already have so it will go where the blind is now. I can always switch the PJ on to make sure it is lined up with the masked borders.
I realised that even 84" would be too big. I can make the size easily but because of the position of the pj, the image will be too far close to the ceiling. It is already quite high as it is (has to be higher than the TV and front speakers)
15-05-2009, 10:21 AM
#9 (permalink)
| | Senior Member
Thanks: Gave 18, Got 56 | Re: Optoma HD700X - Part 2
My screen just turned up, so ill be mounting it tonight when i get home from work, ive got all the bits now and i just picked up some trunking to hide the cables
Lucky for me , my ceiling joists are actually exposed and painted black in the room im going to be putting it, so there shouldn't be any problems locating them |
15-05-2009, 12:00 PM
#10 (permalink)
Thanks: Gave 124, Got 980 | Re: Optoma HD700X - Part 2 Quote:
Originally Posted by monkey00 My screen just turned up, so ill be mounting it tonight when i get home from work, ive got all the bits now and i just picked up some trunking to hide the cables
Lucky for me , my ceiling joists are actually exposed and painted black in the room im going to be putting it, so there shouldn't be any problems locating them  | Good luck.
My screen will take longer. My offer was rejected even though the same seller had accepted the same amount from four other people in the last two months for the same screen.
edit.
The PJ is now £470 at Amazon (no screen). http://www.amazon.co.uk/Optoma-HD700...394135&sr=8-15
16-05-2009, 11:21 AM
#12 (permalink)
I think I may have asked this before but cannot find the post now. Anyone with the 84" Panoview screen from Plays offer, what is the drop of the screen. I can make use of the diagonal but it needs to be able to down as far as 130cm so I can put it up on the ceiling. Is there plenty of black above the viewable area?
16-05-2009, 4:02 PM
#13 (permalink)
| | Member
Thanks: Gave 31, Got 26 | Re: Optoma HD700X - Part 2 Quote:
Originally Posted by nwgarratt I think I may have asked this before but cannot find the post now. Anyone with the 84" Panoview screen from Plays offer, what is the drop of the screen. I can make use of the diagonal but it needs to be able to down as far as 130cm so I can put it up on the ceiling. Is there plenty of black above the viewable area? | The drop when fully extended is roughly 55"! The black area above the white area is roughly 13"! Hope this helps, MichaeL!
16-05-2009, 5:12 PM
#14 (permalink)
Originally Posted by AlomMichaelMiah The drop when fully extended is roughly 55"! The black area above the white area is roughly 13"! Hope this helps, MichaeL! | Thanks.
I actually found a pdf for the screen on Optomas site. It saids the same. 140cm/55" and 30cm/12".
Finding a screen is becoming a pain now. I have decided while electric would be nice, I think a manual pull down will do. The Panoview would fit in what space I have.
17-05-2009, 9:25 PM
#15 (permalink)
| | Senior Member
Thanks: Gave 313, Got 31 | Re: Optoma HD700X - Part 2
Just ordered my Optoma HD700X from Amazon today
Will the Optoma HD700X do 1080p?
Tv: LG 32LC3R -lcd|sky +|DVD player:Toshiba SD330E| Amp:SonySTR-DE695S|Speakers: Mordaunt short,MS302,MS304,MS308 subwoofer|Consoles:xbox 360,PSP,PS3 40gb|Panasonic DMR-EZ27 dvd recorder||OPTOMA HD700X PJ|Panasonic DMP-BD35EB-K blu-ray player.
Reason: grammer
