AVForums - Free Audio Visual electronics advice and information
AVForums.com twitter page AVForums.com facebook page AVForums is a member of CEDIA. THX certified reviewer.  Click for more information. AVForums reviewers are ISF Certified.  Click for more information.
Forum List Register Blogs Information Social Groups Search Today's Posts Mark Forums Read
Go Back   AVForums.com > Forums > Video Electronics > Projectors
Latest popular product pricesPowered by
Epson EH-TW450
Optoma HD200X
Acer X110
Optoma EP761
Epson EH-TW450
Optoma HD200X
Acer X110
Optoma EP761
Optoma ES526
Panasonic PT-AE4000
3M Mpro150
Benq MP727
Optoma ES522
Toshiba TDP-S25U
 More...Prices updated July 30th at 1:30pm and include delivery.
LinkBack Thread Tools
Old 15-04-2009, 7:17 AM   #1
KISSMAN's Avatar
Thanks: Gave 0, Got 14
best dlp 720p projector sub £400
As it states what's the best sub£400 dlp with either dvi or hdmi output
http://www.tranzmission.myby.co.uk/INDEX20.htm
CLICK ABOVE FOR FILM MEMORABILIA
KISSMAN is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Share on Twitter
Old 15-04-2009, 7:07 PM   #2
Thanks: Gave 8, Got 7
Re: best dlp 720p projector sub £400
A 720p PJ for that price? New? Doesn't exist AFAIK. Check the sticky at the top there.
Second-hand is a better bet with that budget.
KesGreen is offline
Old 15-04-2009, 7:43 PM   #3
Thanks: Gave 7, Got 1
look for a secondhand Infocus IN model
teb2doc is offline
Old 15-04-2009, 8:47 PM   #4
Abu
Abu's Avatar
Thanks: Gave 371, Got 196
optoma hd700x, you might find one new. Or as others have said second hand models are a good idea. I think everyone will advise you to wait until you have £500 saved though, the options open to you then will be far far greater.
It just keeps getting faster and faster.
In this house we obey the laws of thermodynamics!
Abu is offline
Old 15-04-2009, 9:41 PM   #5
Anim's Avatar
Thanks: Gave 38, Got 57
In78 is the first 720p model and they go up from there, but I doubt your budget is enough.
Look in the AVForums projector classifieds, plenty of 720p projectors pop up for sale in there for your budget.
EDIT : Heres one... http://www.avforums.com/forums/tv-pr...ma-screen.html
Ta
Geoff
PS3, XBox360, Wii, Marantz SR-6003 Receiver, Samsung 42" 1080p LCD + 92" Infocus In78 Projector
PSN=Anim XBOX360Tag=Anim001
Anim is offline
Old 16-04-2009, 11:09 AM   #6
I would think you would be looking more around the £450 -£470 (inc Vat) mark for something new that's decent.
Optoma Home Theater Series HD65 Projector Projector HD65 - Microwarehouse - Buy The Best Deals Online.
rick2030 is offline
Old 18-04-2009, 1:55 PM   #7
KISSMAN's Avatar
WELL after much research between most of the mid price optomas is some have hdmi some dont but seem identical in every other way and seeing as i have an hdfury i can save a lot of money ie the game times seem almost the same apart from hdmi and i can get a 3000 for £299 same with the other optomas
KISSMAN is offline
Old 18-04-2009, 2:49 PM   #8
The GT-3000 is not a 720p PJ though - hence the price.
KesGreen is offline
Old 18-04-2009, 3:56 PM   #9
KISSMAN's Avatar
NEITHER is my hitachi but with a hdfury im getting 720p 1080i
KISSMAN is offline
Old 18-04-2009, 4:19 PM   #10
Darkstar_surfer's Avatar
Thanks: Gave 25, Got 54
With an attitude that that you will not get much help. It does not matter how good the source is, HD Fury or not, a 420p PJ will always be a 420 PJ.
You do understand the phrase HD Ready.
__Dark in here isn't it___
Panasonic 50PHD6, Optoma GT7000 + 81" Electric Screen, Yamaha RX-V2700, Rotel RMB-1075,Pioneer 868, Arcam CD72, Sony S370, Rega Planar 3, Netgem I-Player, Manhattan Plaza 250 (250GB), Monitor Audio R225 (3 off) & R180 (2 off) and BK Monolith. Bedroom - Panasonic 42PWD6
Darkstar_surfer is offline
Old 18-04-2009, 4:45 PM   #11
Thanks: Gave 21, Got 34
IMO, I would save the money you are going to spend on the GT-3000 and either wait until you have enough to get a Optoma HD65 or HD700x or get a second hand 720p model from the classified section. With the GT-3000 you won't see much of a difference in PQ than your Hitachi PJ-LC9.
The GT-3000's native resolution is 800x600 so even if you use a HDFury, it will scale the 720p or 1080i image back to 800x600.
My Blog
Samsung LE40R83BD - Sony KDL32V4000 - BenQ W100 - Xbox 360 - PS3 - Wii - Logitech Z5500 - iPhone 3G - Self Build PC - Sky HD
Skizm123 is offline
Old 18-04-2009, 4:48 PM   #12
KISSMAN's Avatar
HAVE i missed something what u on about attitude just makin a statement that my pj gives 1080i 720p and the only diff between some of the optomas is one has hdmi the other dont,hdfury gives u that and saves u loads of money
KISSMAN is offline
Old 18-04-2009, 5:53 PM   #13
An attitude is classified by putting a whole word in capitals, i.e shouting it.
Just because a source can output in 720p or 1080i Does not mean a PJ will not down scale it back to 420.
Old 18-04-2009, 8:06 PM   #14
I think you may need to continue your research.
KesGreen is offline
Old 18-04-2009, 9:23 PM   #15
Abu
Abu's Avatar
I think you misunderstand the term compatibility.
For example the GT-3000, its output resolution is 800x600 maximum so you are not getting 720p or 1080i, it can take those and make them 800x600 so it is 'compatible'. Regardless of how you feed it the input, even through the hdfury it only takes the image and downscales it to 800x600.
Whereas the GT-7000 actually has an output resolution of 720p so it is hd ready (1280x720), so if you feed it a 720p image it will actually output a 720p image so it is an actual hd projector instead of being 'compatible'.
And then theres the differences in brightness, contrast, throws, so based on how far away the pj is will give different sized images, and lens shift which allows you to put the pj at an angle to the wall or zoom the image.
The same way a tv for £50 is not going to have the same pq and is going to be different in every way to a tv that is £3000 even if they have the same inputs.
Theres probably other things as well. All pj's are different, no offence but you clearly need to do some really basic googling before doing anything.
And like darkstar said you dont come across well, people here are only being helpful.
Abu is offline
Old 19-04-2009, 10:22 AM   #16
KISSMAN's Avatar
well got myself a right barg,a brand new optoma ep720 £175 will defo give me 720p
KISSMAN is offline
Old 19-04-2009, 10:37 AM   #17
Thanks: Gave 876, Got 636
For the benefit of the OP or anyone else that stumbles across this thread: I just googled that PJ and it clearly states the native resolution is 800 x 600 on the page I've linked to here. Also it is a 4:3 format projector, rather than widescreen. While £175 is cheap, it isn't a 720p projector (you need a native resolution of 1280 x 720/768 for that), it will only accept that as an input then it will downscale the image to the lower resolution panel. It's your choice and your money, but it's not what you appeared to be asking for in your original post and thread title.
EDIT: It only has a VGA input that would allow anything approaching HD to be sent to it, which will probably also restrict input frequency to 60Hz rather than 50Hz or 24Hz from BluRay for example. It also doesn't have a DVI or HDMI input as required inb the original post.
JVC HD350, ISCO II, 112" wide 2.35:1 Beamax, DVDO Edge, VideoEQ Pro, Sony 40W2000, Sony BDP-S350, Arcam AV9, P25/3, P1000 & CD73, Monolith, BFD, PMC TB2M-C+, PMC TB2+, M&K K4 & K5.
KelvinS1965 is offline
Old 19-04-2009, 10:53 AM   #18
KISSMAN's Avatar
close thread
KISSMAN is offline
Old 19-04-2009, 10:53 AM   #19
Anim's Avatar
Kissman, your confusing data projectors with home cinema projectors. to be 720p the projector must be able to produce 720 lines in the Vertical e.g. 1280x720 and hence 720p. This projector is 800x600 so thats 600p which is not a HD format.
Anim is offline
Old 19-04-2009, 12:52 PM   #20
I've editted my above post as maybe I was a little harsh; I think the OP has just made the mistake of mixing input resolution with the display's own resolution. No offence intended to KISSMAN.
Old 19-04-2009, 5:31 PM   #21
KISSMAN's Avatar
none taken
KISSMAN is offline
KelvinS1965 (19-04-2009)
Old 21-04-2009, 7:16 PM   #22
KISSMAN's Avatar
WELL new pj came today optoma ep720 ,big diff from lcd to dlp more cinematic no screen door hooked it up to my blu ray well impressed,only saw a couple of rainbows nowt serious
KISSMAN is offline
720p, dlp, projector, £400
Optimised for Firefox
AVForums.com is owned and operated by M2N Limited
Copyright © 2000-2010 M2N E. & O. E.
