hd65 help
Old 22-03-2009, 6:02 PM   #1
1,444, Level: 8
Points: 1,444, Level: 8 Points: 1,444, Level: 8 Points: 1,444, Level: 8
Thanks: Gave 1, Got 1
hd65 help
hi everyone if anyone could give me advice ill be most greatfull i brought a hd65 of ebay today second hand and when the projector is put on a level surface the piture is projected on the ceiling i have to prop the back up with books to get the piture where i want it is the a setting anywhere whitch i could change to get it shooting straight or are all hd65s like this????
Old 22-03-2009, 8:55 PM   #2
Barry_'s Avatar
7,915, Level: 21
Points: 7,915, Level: 21 Points: 7,915, Level: 21 Points: 7,915, Level: 21
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 543, Got 426
Re: hd65 help
It's Broken Mate - sold a duff projector
Only Kidding
It projects upwards (or downwards if ceiling mounted) - they call it offset - changes depends on distance to screen. You want to have the projector at about knee height and keep projector unit as level as possible.
If you have the manual see page 16 - shows how the picture is thrown upwards. It you have not got a manual go to optoma.co.uk - you can download it from there
Old 23-03-2009, 6:25 PM   #3
1,444, Level: 8
Re: hd65 help
i cant find the stting for offset its not in the manuel
Old 23-03-2009, 6:26 PM   #4
1,444, Level: 8
Re: hd65 help
is there any way to get it going straight
Old 23-03-2009, 10:16 PM   #5
Barry_'s Avatar
7,915, Level: 21
Activity: 0.8%
Re: hd65 help
You can't change this - its normal
1 - Just check a few things - firstly i would open the menu - go to options and reset back to factory default settings - just in case who ever used it before used any keystone corections etc.
2 - check page 16 again (well that is the page on my download - install section - adjusting image size) to check that all is ok with the projected image - place projector on the floor as level as possible & check against the table to see if image is projected in the right place. For example project a 90" picture on to wall - so the distance is 3.09 meters from the wall to the lens - at wide zoom (this is either total full zoom or total minimum zoom not sure which - lol) The bottom of the picture should be 21cm offset plus distance from floor to centre of lens - so say the distance of floor to the centre of lens is 7cm add 21cm to this equals 28cm - this should be the bottom of the projected image. (see picture above table on page 16 to see what i mean)
If ok - maybe you just need to place the projector lower - ie on a coffee table.
Hope this helps
Powered by
 Latest popular product prices
Aiptek PocketCinema T15
4 prices from
 £90.53 Click to show/hide the offers
Optoma Pico PK120
3 prices from
 £134.99 Click to show/hide the offers
Acer C110
3 prices from
 £148.80 Click to show/hide the offers
Dukane ImagePro 8758
1 price
 £192.98 Click to show/hide the offers
Optoma DS211
6 prices from
 £228.96 Click to show/hide the offers
Acer X110P
6 prices from
 £238.75 Click to show/hide the offers
Benq MS500
5 prices from
 £238.00 Click to show/hide the offers
Optoma Pico PK301
4 prices from
 £248.97 Click to show/hide the offers
 Updated February 10th at 3:30am. Prices include delivery.
