| Re: Planar 7010 light blobs and flickering, any help?
Thanks for your replies guys.
This is my 6th projector and never noticed dust on the inside of the lens before, but on the other hand, never needed to have a look before lol.
Not sure if the light blobs are anything to do with the dust and the light patches on the screen i think are just light blobs on the screen but they blend in a little.
I have discovered another little curiosity though, the settings seem to change themselves. When i first installed the projector i set the brightness, contrast and so on, only to find that when i turned it on the next time the settings would be different.
I thought that it was me not doing something right but the other night i was watching a film and the settings changed half way through the film. For example, it turned the blank screen from black to red and the bulb from eco to normal! And when i pressed the M1 button to load my setting again it changed everything (screen upside down and reversed). So i think the unit is a little sick.
Planar have replied and asked me to call them and have the projector in front of me. So this weekend i will be taking it down and calling them to see what they have to say.
James.
